Where do these wires go?
Thank you for the advice. "Chromatically Challenged" is right. I can't stand the PC crap.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
4 Led Driving Lights
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Braided Lines
R6 4 Piston Calipers
Stainless Bolt Kit
Maier Fairing
Dyna Balancing Beads
Spin On Oil Filter
Stebel Nautilus Horn
Plasti Dip Rims
ISO GripsComment
Does anybody know what these are?
Also, can someone take a picture or explain to me ho the spring on the rear brake lever is supposed to be assembled? I can't figure it out. It's the spring that retracts the lever that goes into the rear master cylinder. The microfiche doesn't show anything. Thanks1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO GripsComment
Hey Rev,
I don't have any photos, but the spring grabs the brake lever from underneath to push it upwards. The other end wedges/leverages against the frame with tension to keep the brake lever UP.
Those parts look like they might go to the airbox, but not sure.T. C. Gresham
1980 XS1100G "Dolly G" Full Dresser (with a coat of many colors
Awesome. Thanks for the info. I now see the clamps in the microfiche. Any suggestion about the brake spring?1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO GripsComment
parts fiche from boats.net
http://www.boats.net/parts/search/Ya...DER/parts.htmlwhere are we going, and why are we in this hand basket?
Iowa the Beautiful Land 1980 XS1100SGComment
I am trying to hook up a digital dash to my 79 standard. I need to find the wire for the tach. I can't seem to find it on the wiring diagram. Also, I am color blind and I cant figure out the difference between the right turn signal and the oil light. Any help would be greatly appreciated. Thanks
Jared1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO GripsComment
Hey Rev,
Your digital dash won't work with the xS11 tach wire anyways!!! Our tachs are electronic, but they read pulses from 1 leg of the 3 legs/phases of the Alternator, not the ignition coils!
Your dash unit should provide info about connecting the signal wire to the negative side of one of the ignition coils,(you will have to run a wire) and hopefully it will have a variety of cylinder settings, 2, 3, 4, 6, 8 to select from. You will want the 2 cylinder setting IIRC.
As for the turn signal and oil light, if you have the battery still installed, just put your voltmeter on the wire, and turn the key on....if you get power, then it's the oil light....it comes on with key on, and goes OFF when pressure reaches enough to shut switch off. Turn signal will have no power until you hit the turn signal switch!
T.C.T. C. Gresham
ok, so i hooked up the battery to see if my connections worked and I looked at my fuse box and i am missing the large cable that connects to what i gather is the starter motor switch. here is a pic
i have know idea where that cable is, i need to find it or make a new one. Does this wire terminate at the starter motor? Thanks
Also, what is this fuse?
Jared1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO GripsComment
That would be correct. See if there's a wire coming out of the starter and trace it back.
The other fuse clip is for the accessory terminal right next to it. No need to fuse it up yet. Maybe later when you add stuff like a cigarette lighter.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
Awesome. Thanks for the info.1979 xs1100f
New Fuse Box
Progressive Shocks
Gold Valve Emulator
Dyna Coils
Electronic Flasher
Led Headlight
Led Turn Signals
2nd Gear Fix
Auto Cam Tensioner
Digital Dash
Stainless Bolt Kit
Maier Fairing
Spin On Oil Filter
Plasti Dip Rims
ISO GripsComment
I would say just ditch the accessory fuse holder. No sense using that old glass fuse when you have slots to spare in the fuse box.Nathan
Theodore RooseveltComment
Hey Nate,
Oh contrare!
The AUX screw terminals are handy for wiring up accessories. You can pull the AUX terminal off of the backing plate, and route the wires to the fuse block so you can use the ATCO fuses and still retain the AUX terminal/screws access. You just have to rewire it to bypass the OEM glass fuse slot...it wasn't hard, I just unscrewed the wires connected in the back of the assembly to reroute them thru the new fuseblock! Sorry, I don't have a diagram or photos.
T.C.T. C. Gresham
Why bother messing with it when you still have to baypass the fuse? Just wire it to the fuse box in the first place! You are adding more unnecessary connections in a circuit.Hey Nate,
Oh contrare!
T.C.Nathan
