Where do these wires go?
  • TheRev
    • Jun 2012
    • 235
    • Madison, Wi.
    Hello All
    I have rebuilt the wire harness and have mostly installed it on my 79 xs1100f, however I can't figure out where these wires go. They look like ground wires so I assume they mount to the frame, but where?
    1979 xs1100f
    New Fuse Box
    Progressive Shocks
    Gold Valve Emulator
    Dyna Coils
    Electronic Flasher
    Led Headlight
    Led Turn Signals
    4 Led Driving Lights
    2nd Gear Fix
    Auto Cam Tensioner
    Digital Dash
    Stainless Braided Lines
    R6 4 Piston Calipers
    Stainless Bolt Kit
    Maier Fairing
    Dyna Balancing Beads
    Spin On Oil Filter
    Stebel Nautilus Horn
    Plasti Dip Rims
    ISO Grips
    Originally posted by TheRev
    Hello All
    Hi Rev,
    they go on one of the bolts that hold the regulator/rectifier onto the frame.
      hi rev,
      ............. +1
        And make sure you have clean, bare metal for them to ground to....
        • TheRev
          • Jun 2012
          • 235
          • Madison, Wi.
          Both go on the same bolt?
          1979 xs1100f
          New Fuse Box
          Progressive Shocks
          Gold Valve Emulator
          Dyna Coils
          Electronic Flasher
          Led Headlight
          Led Turn Signals
          2nd Gear Fix
          Auto Cam Tensioner
          Digital Dash
          Stainless Bolt Kit
          Maier Fairing
          Spin On Oil Filter
          Plasti Dip Rims
          ISO Grips
            Hi Rev,
            yes. Well, they both go to the rear bolt on my SG anyway.
            The reg/rect has a conductive metal case so I'd suppose it don't matter which bolt is used or even if both of them are.
            Attach them whichever way looks the tidiest.
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              Thank you all for your help.
              Jared
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
              • TheRev
                • Jun 2012
                • 235
                • Madison, Wi.
                You all were so quick with a reply so I thought I would ask another question. I have almost all my connections made but these two wires have me stumped. By the way I am color blind so my wireing diagram is very hard to figure out. If you can help I would appreciate it.
                1979 xs1100f
                New Fuse Box
                Progressive Shocks
                Gold Valve Emulator
                Dyna Coils
                Electronic Flasher
                Led Headlight
                Led Turn Signals
                2nd Gear Fix
                Auto Cam Tensioner
                Digital Dash
                Stainless Bolt Kit
                Maier Fairing
                Spin On Oil Filter
                Plasti Dip Rims
                ISO Grips
                • jayel
                  • Apr 2012
                  • 152
                  • Birmingham, Iowa
                  looks like pink (lighter) and brown +12v (darker wire) horn wires
                  where are we going, and why are we in this hand basket?
                  Iowa the Beautiful Land 1980 XS1100SG
                    Hi Jared,
                    the wiring diagrams in Clymers are all black and white with the colors tagged by a letter code.
                    But that don't help if you can't tell what colors the wires are, eh?
                    I had problems getting my revised rightside indicator to work when Mr Stupid didn't notice that a dark brown wire was in fact a black one until the 3rd time the fuse blew.
                    Jayel sez the wires in the photo go to the horn.
                    Let me advise that you connect them to the relay that powers the Stebel-Nautilus mini air horn that you should purchase.
                    139dB really gets you noticed.
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      Where do you mount that horn?
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                        Hi Jared,
                        I bent up a bracket from a strip of ~2" wide x 1/8" thick aluminum.
                        The bike end bolts to the right side lower triple tree clamping bolts
                        and the horn end is bent so the horn faces forward.
                        Note that you must use the relay that comes with the horn or it won't get enough power to work properly.
                        • jayel
                          • Apr 2012
                          • 152
                          • Birmingham, Iowa
                          Hi Jared,
                          the Harley dealer I worked for back in the late 60's 70's was color blind too, of course wiring was simpler back then (no ground wires) two colors for him lighter and darker LOL
                          • TheRev
                            • Jun 2012
                            • 235
                            • Madison, Wi.
                            Yah, this wiring stuff sucks when you can't see the damn colors. However, my guess is the wires are pretty faded anyhow so it might be hard for all you non color blind people as well. Anyhow, can anybody help me find a wire for my led running lights to tap into. The lights indicate that one wire is black and the other red. I believe the black one would be ground, right? And the red for power, right? If I tie all the black wires together and ground them that should be acceptable, but where should I get the power for the red wires? Thanks
                            1979 xs1100f
                            New Fuse Box
                            Progressive Shocks
                            Gold Valve Emulator
                            Dyna Coils
                            Electronic Flasher
                            Led Headlight
                            Led Turn Signals
                            2nd Gear Fix
                            Auto Cam Tensioner
                            Digital Dash
                            Stainless Bolt Kit
                            Maier Fairing
                            Spin On Oil Filter
                            Plasti Dip Rims
                            ISO Grips
                              Connect the red wire of your LED lights to the soild blue wire in the headlight bucket or at the tail light. it will supply power when the key is switched to the on position. Black wire to chassis ground.
