Where do these wires go?
    Originally posted by TheRev
    Yah, this wiring stuff sucks when you can't see the damn colors. However, my guess is the wires are pretty faded anyhow so it might be hard for all you non color blind people as well. Anyhow, can anybody help me find a wire for my led running lights to tap into. The lights indicate that one wire is black and the other red. I believe the black one would be ground, right? And the red for power, right? If I tie all the black wires together and ground them that should be acceptable, but where should I get the power for the red wires? Thanks
    Hi Jared,
    the PC police insist that you can't call yourself that any more, these days you are "Chromatically Challenged".
    And yes, run the black wires to ground and steal power from the wire that goes to the tail light to feed the red wires.
    • TheRev
      • Jun 2012
      • 235
      • Madison, Wi.
      Thank you for the advice. "Chromatically Challenged" is right. I can't stand the PC crap.
      1979 xs1100f
      New Fuse Box
      Progressive Shocks
      Gold Valve Emulator
      Dyna Coils
      Electronic Flasher
      Led Headlight
      Led Turn Signals
      4 Led Driving Lights
      2nd Gear Fix
      Auto Cam Tensioner
      Digital Dash
      Stainless Braided Lines
      R6 4 Piston Calipers
      Stainless Bolt Kit
      Maier Fairing
      Dyna Balancing Beads
      Spin On Oil Filter
      Stebel Nautilus Horn
      Plasti Dip Rims
      ISO Grips
      • TheRev
        • Jun 2012
        • 235
        • Madison, Wi.
        Does anybody know what these are?
        Also, can someone take a picture or explain to me ho the spring on the rear brake lever is supposed to be assembled? I can't figure it out. It's the spring that retracts the lever that goes into the rear master cylinder. The microfiche doesn't show anything. Thanks
        1979 xs1100f
        New Fuse Box
        Progressive Shocks
        Gold Valve Emulator
        Dyna Coils
        Electronic Flasher
        Led Headlight
        Led Turn Signals
        2nd Gear Fix
        Auto Cam Tensioner
        Digital Dash
        Stainless Bolt Kit
        Maier Fairing
        Spin On Oil Filter
        Plasti Dip Rims
        ISO Grips
          Hey Rev,
          I don't have any photos, but the spring grabs the brake lever from underneath to push it upwards. The other end wedges/leverages against the frame with tension to keep the brake lever UP.
          Those parts look like they might go to the airbox, but not sure.
            • 2104
            Thanks
            Those pieces are brackets to retain the front brake hoses using one of the fender bolts on each side and the clamp on the brake hose.
            • TheRev
              • Jun 2012
              • 235
              • Madison, Wi.
              Awesome. Thanks for the info. I now see the clamps in the microfiche. Any suggestion about the brake spring?
              1979 xs1100f
              New Fuse Box
              Progressive Shocks
              Gold Valve Emulator
              Dyna Coils
              Electronic Flasher
              Led Headlight
              Led Turn Signals
              2nd Gear Fix
              Auto Cam Tensioner
              Digital Dash
              Stainless Bolt Kit
              Maier Fairing
              Spin On Oil Filter
              Plasti Dip Rims
              ISO Grips
              • jayel
                • Apr 2012
                • 152
                • Birmingham, Iowa
                parts fiche from boats.net
                http://www.boats.net/parts/search/Ya...DER/parts.html
                where are we going, and why are we in this hand basket?
                Iowa the Beautiful Land 1980 XS1100SG
                • TheRev
                  • Jun 2012
                  • 235
                  • Madison, Wi.
                  I am trying to hook up a digital dash to my 79 standard. I need to find the wire for the tach. I can't seem to find it on the wiring diagram. Also, I am color blind and I cant figure out the difference between the right turn signal and the oil light. Any help would be greatly appreciated. Thanks
                  Jared
                  1979 xs1100f
                  New Fuse Box
                  Progressive Shocks
                  Gold Valve Emulator
                  Dyna Coils
                  Electronic Flasher
                  Led Headlight
                  Led Turn Signals
                  2nd Gear Fix
                  Auto Cam Tensioner
                  Digital Dash
                  Stainless Bolt Kit
                  Maier Fairing
                  Spin On Oil Filter
                  Plasti Dip Rims
                  ISO Grips
                    Hey Rev,
                    Your digital dash won't work with the xS11 tach wire anyways!!! Our tachs are electronic, but they read pulses from 1 leg of the 3 legs/phases of the Alternator, not the ignition coils! Your dash unit should provide info about connecting the signal wire to the negative side of one of the ignition coils,(you will have to run a wire) and hopefully it will have a variety of cylinder settings, 2, 3, 4, 6, 8 to select from. You will want the 2 cylinder setting IIRC.
                    As for the turn signal and oil light, if you have the battery still installed, just put your voltmeter on the wire, and turn the key on....if you get power, then it's the oil light....it comes on with key on, and goes OFF when pressure reaches enough to shut switch off. Turn signal will have no power until you hit the turn signal switch!
                    • TheRev
                      • Jun 2012
                      • 235
                      • Madison, Wi.
                      ok, so i hooked up the battery to see if my connections worked and I looked at my fuse box and i am missing the large cable that connects to what i gather is the starter motor switch. here is a pic
                      i have know idea where that cable is, i need to find it or make a new one. Does this wire terminate at the starter motor? Thanks
                      Also, what is this fuse?
                      Jared
                      1979 xs1100f
                      New Fuse Box
                      Progressive Shocks
                      Gold Valve Emulator
                      Dyna Coils
                      Electronic Flasher
                      Led Headlight
                      Led Turn Signals
                      2nd Gear Fix
                      Auto Cam Tensioner
                      Digital Dash
                      Stainless Bolt Kit
                      Maier Fairing
                      Spin On Oil Filter
                      Plasti Dip Rims
                      ISO Grips
                      • GLoweVA
                        • Jun 2011
                        • 1957
                        • Virginia Beach, VA.
                        That would be correct. See if there's a wire coming out of the starter and trace it back.
                        The other fuse clip is for the accessory terminal right next to it. No need to fuse it up yet. Maybe later when you add stuff like a cigarette lighter.
                        80G (Green paint(PO idea))
                        The Green Monster
                        Got him in '04.
                        bald tire & borrowing parts
                        Scarlet
                        Got her in '11
                        Ready for the twisties!
                        81H (previously CPMaynard's)
                        Hugo
                        Cold weather ride
                        • TheRev
                          • Jun 2012
                          • 235
                          • Madison, Wi.
                          1979 xs1100f
                          New Fuse Box
                          Progressive Shocks
                          Gold Valve Emulator
                          Dyna Coils
                          Electronic Flasher
                          Led Headlight
                          Led Turn Signals
                          2nd Gear Fix
                          Auto Cam Tensioner
                          Digital Dash
                          Stainless Bolt Kit
                          Maier Fairing
                          Spin On Oil Filter
                          Plasti Dip Rims
                          ISO Grips
                            I would say just ditch the accessory fuse holder. No sense using that old glass fuse when you have slots to spare in the fuse box.
                              Hey Nate,
                              Oh contrare! The AUX screw terminals are handy for wiring up accessories. You can pull the AUX terminal off of the backing plate, and route the wires to the fuse block so you can use the ATCO fuses and still retain the AUX terminal/screws access. You just have to rewire it to bypass the OEM glass fuse slot...it wasn't hard, I just unscrewed the wires connected in the back of the assembly to reroute them thru the new fuseblock! Sorry, I don't have a diagram or photos.
                                Hey Nate,
                                Why bother messing with it when you still have to baypass the fuse? Just wire it to the fuse box in the first place! You are adding more unnecessary connections in a circuit.
