While I laud your enthusiasm, might I suggest that you find out where the problem is, what caused it, and what to do so that it is not repeated. Removing and replacing a head involves a lot more than ACCT installation, and if you don't know what the original cause was, how do you know it won't be repeated when you replace the head?
Valves are another one of those hard to find items, and should be sheltered from learning mistakes.
No offense intended. CZ
And maybe damaged pistons if the valves hit them hard enough.
