Fuel
I got an XS1100 H that PO had removed the octy and replaced the petcocks with what is best described as 3 position valves. There is Off, On, and Reserve and they each have only one outlet. So there are only 2 fuel lines - one each w/filter going to each pair of carbs. It is definitely a cleaner setup.
Never have seen this particular type of fuel valve before. Each has a lever that clocks from front to back. Front is Off, rear is On, middle is Reserve. They actually look pretty nice - polished aluminum. Will get some pix later.
MP
MP
CZ
