Top Five Upgrades
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    #61
    I see quite a few suggesting new rear shocks. Whats wrong with the stock?
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
    • jwhughes3
      • 2798
      • Home of the Alamo
      #62
      NLA
      John
      '81 XS1100H - "Enterprise"
      • pbaker27
        • Jun 2012
        • 108
        • Shakopee, Minn.
        #63
        Originally posted by Tat2demon
        That one is VERY expensive. I picked up one from a 2001 Raptor for $9 with priority mail included.
        http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
        So this one would work right? Off of a 2004, its $12.95 with free expedited shipping and does have a 14 day return policy.
        http://www.ebay.com/itm/Yamaha-Rapto...b142c6&vxp=mtr
        Hydra'82 XJ1100 Frankenbike with a '79 engine
        ~dubbed "Hydra" by a friend, because "once one problem is fixed, another rears its ugly head!"
        • James England
          • 3039
          • North of England
          #64
          They're a bit basic. Many models have non-adjustable damping and only 5 spring positions.
          • Tat2demon
            • Jun 2012
            • 718
            #65
            Yep that one should be fine. Youll have to grind or file the top hole towards the center of the unit just a little. Some people use files, I used a small grinding bit on a Dremmel.
            Nate
            K+N Air Filter
            88 Voyager XII
            81 XJ650 Maxim
            • pbaker27
              • Jun 2012
              • 108
              • Shakopee, Minn.
              #66
              Cool thanks! Bought it, hopefully will get it by this weekend so I can actually ride
              • MPittma100
                • Aug 2011
                • 2359
                Upgrades
                Where to get a blade fuse box???
                MP
                1981 XS1100H Venturer
                K&N Air Filter
                ACCT
                Custom Paint by Deitz
                Geezer Rectifier/Regulator
                Stebel Nautilus Horn
                EBC Front Rotors
                Limie Accent Moves On In 2015
                Mike
                • Tat2demon
                  • Jun 2012
                  • 718
                  #68
                  Nate
                  K+N Air Filter
                  88 Voyager XII
                  81 XJ650 Maxim
                  • Zeke on Wheels
                    • Jun 2012
                    • 38
                    • Frederic, Mi.
                    #69
                    So, what does the fork brace do for ya? I see that most of you have it on your list. I have only been riding mine for a couple of months now.
                    80 XS1100 SG "Iron Horse"
                    • jwhughes3
                      • 2798
                      • Home of the Alamo
                      #70
                      Stabilizes front fork flex.
                      Go high speed into a leaning turn and waviness in the road can lead to serious wobble due to flexy forks. This can be worsened when bike is loaded, two up or with gear.
                      If you don't go over 50 mph around town you won't notice the difference.
                      John
                        Yes. The fork tubes are flexi. If you don't ride hard, you may not notice any difference after installing a fork brace. The stock suspension is very soft and that hides some of the flexible fork issue. At least, that's how I see it and I'm a nobody. I put new custom wound straight rate springs and Gold Valve emulators in my forks. That made it very evident that the forks flex a lot. I can actually see it. The fork brace helps a lot, but is not a cure. After the other fork modifications, the brace becomes more of a necessity.
                        • CodyLane
                          • Apr 2010
                          • 35
                          • Vista, CA
                          #72
                          -ZRX1200 Carb Swap
                          -Dynatek 3 Ohm Coil Upgrade
                          -Modern Fuse Block
                          -Raptor Auto CCT
                          -Windscreen
                          80 XS11 "Bellatrix"- MAC 4-1, ZRX1200 carbs, Dynatek Coils, Raptor CCT
                          • maxrageous
                            • Aug 2010
                            • 22
                            • Lansing, MI 48910
                            #73
                            upgrades/replica fuse block
                            Hi folks! I came up with a niffty replacement for the stock fuse block. It will fit into the stock box and use the same or longer glass fuses. It doesn't look any different than the original with the outside cover on. If anyone wants to see the photos of this item write to me at my personal E-mail address.
                            maxrageous@yahoo.com. This is, maybe, a way I can make a positive addition to this site. Thank you all for the great tips and info.
                            Max Rageous
                            the "not quite right in his head" rider.
                            • pbaker27
                              • Jun 2012
                              • 108
                              • Shakopee, Minn.
                              #74
                              And where to get these parts? Off of ebay for the carbs? Would the ZRX1200s need to be rejetted?
                              -ZRX1200 Carb Swap
                              • ExcessiveBiker
                                • Nov 2006
                                • 60
                                • Texas
                                #75
                                XS11 mods in order of installation
                                XS1100SH 1981
                                Regular Handlebars, original SH bars are a real PAIN in the wrist
                                Modern Fuse Block, original disintigrated
                                Vetter Fairing, nice for winter and rain
                                Tcat Fork Brace, keepin it stiff
                                AGM battery, I'll never own another lead/acid M/C batt.
                                Stainless Steel Lines, feeling solid
                                Totally no second gear, saves on shifting, PITA to change
                                Tcat SOFCA (Spin on filter/oil cooler adapter, single unit)
                                Dyna Green coils, originals split after about 45,000 miles
                                Owned for 6 years and 60,000 miles to date.
                                ExcessivBiker
