Top Five Upgrades
  • Joab
    • Aug 2010
    • 472
    • Ozark, Alabama
    Top Five Upgrades
    So here is a fun little question for all you folks out there...
    What are the top five upgrades you would perform on these bikes when you first buy them? Should get some interesting responses on this one I should think!
    Joab
    "If nothing else, it will be interesting..."
    ______________________________________________
    1979 XS1100SF
    1972 XS2 650
    Ozark, Alabama
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    1 Fuse box!
    2 Auto can chain tensioner
    3 in-line fuel filters
    Those would be my top 3 for sure.
    beyond that, maybe some SS brake lines, led lights, the list could grow pretty big from there.
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
      Springs & shocks.
      • LoHo
        • Sep 2002
        • 1342
        • Fresno, CA
        A good fork brace.
        A modern fuse block.
        Progressive springs.
        Self-adjusting cam tensioner.
        A wind screen.
          Hi Joab,
          Tkat fork brace.
          Stainless brake lines.
          Rear shock upgrade.
          Fork emulator valves.
          Auto CCT.
          +#6 Spade fuse block.
            My list...
            #1 Fuse Block replacement
            #2 Stainless Steel brake lines
            #3 750 FD conversion
            #4 Fork Brace
            #5 Shocks and fork springs
            • DCII
              • Jul 2010
              • 792
              • Centerville, Ohio
              My list for a Special
              1, Fork Brace
              2, Regular Handlebars
              3, Stainless Steel Lines
              4, Modern Fuse Block
              5, Auxiliary lighting
                1) auto CCT
                2) 750/850 final drive
                3) XJ rear shocks
                4) Storage (bags ect.)
                5) windshield/fairing
                • Aches n Pains
                  • 349
                  • Reston, Va.
                  1. Fuse block
                  2. Automatic cam chain tensioner (Venture mod)
                  3. Handle bar offset that moves bars to the rear slightly (I'm old)
                  4. In line fuel filter and shut off valve (protect against petcock failure)
                  5. Spin on oil filter
                  To do:
                  Stainless oil lines
                  Tkat fork brace
                  1995 KZ100P
                  Pods, jets, pipes, cam adjuster, oil cooler
                  1977 Ironhead - custom build
                  Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                  Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
                  • TADracer
                    • 1417
                    • Kenner, Louisiana USA
                    Seems like forks, fuses, filters, springs and tensioners are the weak points everyone has done a fix on. Me too! So I will expand.
                    6. Carburetor upgrade to Keihins from a ZRX-1200.
                    Best thing I have ever done on my machine.
                    Mike Giroir
                    79 XS-1100 Special
                      It really depends on how your going to use/ride it. If your going to hammer on it the performance mods are what you need to concentrate on. If your going to travel and carve some far away roads you need to concentrate on the comfort (bags, fairing, FD ect).
                      Both ways you could use the fuse box and suspension upgrades on.
                        Small drain plug on stock oil filter housing to make changes clean.
                        faring and bags
                        replaced sealed beam with conversion for H4 bulb (78E)
                        fork brace
                        LED signals on either front or rear with LED brake lights
                        VW voltage regulator while using stock rectifier
                        electronic flasher unit
                        replace wheelbarrow bars on specials with anything else
                          The one most missed.....
                          Tubeless rims if you have a '78 or early '79 standard.
                          • James England
                            • 3039
                            • North of England
                            1. Fork brace
                            2. Auto CCT
                            3. Geezer rectifier/regulator upgrade
                            4. Fuse box upgrade to blade fuses
                            5. Dyna coil upgrade + ditch ballast resistor
                            • Gyrogearloose
                              • 162
                              • Coupeville, WA
                              1. fuze box.
                              2. upgrade headlight bulb
                              3. new needles/seats
                              4. hd clutch springs
                              5. rear shocks
                              6. s.s. brake lines.
                              Geno
