Top Five Upgrades
  • JasonRedbeard
    • 109
    • Tuscaloosa, AL
    1. Fuse box update
    2. Auto cam chain tensioner update (A-CCT)
    3. Add inline fuel filters
    4. Pod-style air filters (slight power increase, and makes it soooo much easier to access the carbs)
    5. Braided steel brake lines
    My Special is as old as I am.
    • Joab
      • Aug 2010
      • 472
      • Ozark, Alabama
      Wow, looks like I have some things to pick up. I guess it looks like the Auto Cam Chain Tensioner and fork brace are at the top of the list. Glad to see it isn't only me that feels the Specials bars are not the comfort standard...
      Not sure where I could find tubeless rims though...of course, I need to check to see what is on my bike in the first place.
      Joab
      "If nothing else, it will be interesting..."
      ______________________________________________
      1979 XS1100SF
      1972 XS2 650
      Ozark, Alabama
      • cywelchjr
        XS-XJ Super Guru(Deceased)
        • 4450
        • Sacramento, CA
        All specials unless they have had older standard rims put on them have tubeless rims on them already as they came with tubeless rims from the factory from the beginning.
          • 6765
          One thing not mentioned are the wimpy horns. I just replaced mine with a Stebel nautilus dual air horn with its own wire harness and relay. 139db blaster that sounds like a freight train... I had one on my former ST1100 but it was under the bodywork.It was loud but this one on the XJ being out in the open is even louder...
          Also aux.LED lighting up front...more light better to see and be seen...
          2005 Honda SilverWing 600
          2018 Honda PC-Xpress 150
          • 79XS11F
            • 3563
            • Ottawa, Ont. Canada
            1 - Capable charging system
            2 - Fully electronic ignition / timing
            3 - Stiffer forks or Fork brace
            4 - Capable brakes
            5 - Weight reduction
            Rob
            KEEP THE RUBBER SIDE DOWN
            1978 XS1100E Modified
            1978 XS500E
            1979 XS1100F Restored
            1981 Suzuki GS1100
            1983 Suzuki GS750S Katana
            1983 Honda CB900 Custom
              The Special has a 16" rim though Cy and his F will be a 17".
              80 and 81 Standards have a 17" tubless rim. If you look on ebay at 850 rims, which will fit, you can get up to a 19" I believe.
                How about putting a 130/80-17 tire on it? That will get it closer to the Special.
                  He's looking for tubless Marty.
                  • cywelchjr
                    • 4450
                    • Sacramento, CA
                    79 standards you have to check, but the ONLY difference between the tubeless rear and the tube rear is the rim lock hole(s). Other than that they are the same casting, this has been confirmed by crazy steve comparing both side by side, the front tube and tubeless however are actually different with a different profile so you really need to find the correct rim for the front, unless it's one of the later 79's that came with tubeless rims since not all 79 standards came with tube type rims.
                      Come to think about it Russ has been running a tubless tire on his standard rim for quite a while. All he did was seal up the rim lock hole the same way the tubless valve stem is sealed. With rubber washers.
                      • Pat Kelly
                        • 3046
                        • Golden Valley, AZ
                        5 super-models in bikinis (optional) to wash it.
                        Pat Kelly
                        <p-lkelly@sbcglobal.net>
                        1978 XS1100E (The Force)
                        1980 XS1100LG (The Dark Side)
                        1999 Suburban (The Ship)
                        1994 Dodge Spirit (Son #1)
                        1968 F100 (Valentine)
                        • ddragon63
                          • Jan 2012
                          • 1101
                          • Ridgefield, WA
                          1: gas in the tank
                          2: oil in the case
                          3: air in the tires
                          4: sunshine
                          5: open road in front of me
                          the rest is just a bonus
                          Don
                          old:
                          1989 kawi ex500
                          1996 yzf-r6
                          1999 yzf-r1
                          2001 kawi zx-6r
                          2000 Ducati 748
                          2002 YZF-R1
                          2005 V-Star 1100 Classic
                            Hey Greg,
                            Yes, folks have converted their tubed front rims to be able to use tubeless tires, but due to the bead difference, "we" can not condone this practice. It could lead to the tire coming loose from the rim during an inexpected quick deflation scenario which could lead to a MORE catastrophic handling situation that just the flat tire alone...! HENCE THE BEAD LOCKS designed into the OEM tubed rims! With the tire still well seated against the rim bead, you can still retain "some" handling ability while you're trying to slow down, but if the tire comes off the rim/bead, you are pretty much SOL and will be sliding down the road on your side fairly quickly!
                              Hey Greg,
                              Well "I" was talking about the 17" rear rim. Although this may be a problem in theory I have never heard of it happening.
                              The 19" front rim is pretty standard on ALL XSs, 650 on up through all years it would definitly not be a problem finding a front tubless wheel. However, the 17" is a little more difficult.
                              • ddragon63
                                • Jan 2012
                                • 1101
                                • Ridgefield, WA
                                1979 xs1100sf factory wheels read suitable for tubeless.
                                Don
                                old:
                                1989 kawi ex500
                                1996 yzf-r6
                                1999 yzf-r1
                                2001 kawi zx-6r
                                2000 Ducati 748
                                2002 YZF-R1
