i was originally looking for a suzuki gs650, the guy wouldnt sell it. then he showed me the twins.. sitting in a 6x8 garden shed for 6 years, got both for 800 bucks... had the 81 running within 3 hours, lotsa carb cleaner and a box of pilsner for me havent evn tried the 80 yet its got a grinding noise in the gearbox, maybe someday ill dig into it
want some feed back on my project
Originally posted by jaindl View Posthaha i knew id get some guff about choppin the bike. Too bad i started a week ago. my story is the same as nightengales, so similar i had to laugh.. just a case of me not knowing what i had. as far as chopping goes it will be minimal, keeping the rear suspension, cutting from the shock mount back then adding a full rear fender and modern looking fender strut and rigid mounted solo seat. then turning the front fender about 6 inches to make the front plumb with the frnt axle. i was debating going hardtail, then i put a solid strut in place of the shock and went for a ride.. and that will be the last time i ever think of a rigid frame. haha roads aint that good up north eh.Some make 'em, most just make payments on 'em!
1978 XS 1100E
Vance & Hines Slip on Straight Shot Exhaust
K & N Air filter
Home built forward controls
Vulcan Mustang seat
A little chopped
http://s812.photobucket.com/albums/zz42/Brad_099/
Dont mean to give you any guff on chopping it, talking about putting a torch to a XS2 650 has gotten me some heat as well I just find it ironic that as everyone is slimming down these touring bikes to bobber/choppers, I am trying to build up my Special for distance runs!Joab
"If nothing else, it will be interesting..."
______________________________________________
1979 XS1100SF
1972 XS2 650
Ozark, Alabama
not ridden yet
Originally posted by Brad View PostNice job Nitengale, I think that looks great. Theres a few other members on here who prefer stock, those are ok too. How does it ride at speed with the rake and trail changed?
Originally posted by jaindl View Post....I was debating going hardtail, then I put a solid strut in place of the shock and went for a ride.. and that will be the last time I ever think of a rigid frame. haha roads aint that good up north eh.Fast, Cheap, Reliable... Pick any two
Originally posted by Nightengale View Posti am also thinking about adding this to be better seen and add turn signals, and stay hidden at the same time
it acts as a brake light and has turn signals on each end. and attaches to the underside of the fenderEric Haarstad
Minnesota
1979 XS1100 Special
ghost rider customs
Originally posted by Haarstad View Postwhat is the exact name of this light, or the link to where the picture is?
speedo and key switch replacement
got a few things done today. i recentlly was given a gauge cluster from a special, form GloweVA (george). i was going to try to modify the mounting bracket so that i could just use the speedo centered on the triple tree. but as luck will have it i tried numerous ways, and just couldnt get it to fit the way i wanted. my brother had a 2 inch gauge that he had and i tried it and since i have removed the key switch it fit perfect where the key switch was. I made a custom bracket, and installed it to the holes for the key switch, then mounted the speedo. i did have to modify the back of my head light so that the speedo cable would fit right. i also had to modify the right hand side of the light so that the new switch would fit for the replacement of the key switch.
front view.
the new switch on the right headlight ear
modification to headlight for switch
modification to rear of headlight for speedo cable
i am glad i got to meet a fellow xs'er this weekend and get to meet the "green monster" .
The only bad thing about that custom speedo is it calibrated for the Yamaha speedo drive? If it's a Harley bit, it's going to be way the h**l off... by about 30%Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View PostThe only bad thing about that custom speedo is it calibrated for the Yamaha speedo drive? If it's a Harley bit, it's going to be way the h**l off... by about 30%
and if it doesnt work i at least know the size of what i need to make it fit.
2:1 is a Harley ratio.... You need 2.9:1......Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View Post2:1 is a Harley ratio.... You need 2.9:1......
http://www.mikesxs.net/product/03-0751.html
it says it will work with the xs650 and from what i have read that the 650 gauges will work on our bikes. but i could be wrong.
Mikes has been selling those 2:1 speedos for years, but he doesn't tell you they're accurate....
Yes, the 650 shares the same speedo ratio with the 1100.... but it ain't 2:1...Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View PostMikes has been selling those 2:1 speedos for years, but he doesn't tell you they're accurate....
