Cam Chain adjustment...
Yep, can't leave nuthin' alone... -
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Yep, good thread. And good point Randy.
My little question (so I don't have to pour over all the other threads) is which auto tensioner is the one which bolts right on with no hole modification. As I recall, this would be either the Venture (or Venturer?) or the VMax units?
Anybody have an extra good one?80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
The Venture and V-Max units are the same part, it's the Vision CCT that needs the hole mod. The other difference is the Vision tensioner's spring is much closer to the same rate as OEM, while the Venture/V-Max spring is stiffer. That may or may not effect the wear on the cam chain guide...Fast, Cheap, Reliable... Pick any two
Thanks Steve....The Venture and V-Max units are the same part, it's the Vision CCT that needs the hole mod. The other difference is the Vision tensioner's spring is much closer to the same rate as OEM, while the Venture/V-Max spring is stiffer. That may or may not effect the wear on the cam chain guide...
So has any excessive wear been reported? Again, I don't recall hearing of any yet.80 SG
81 SH in parts
99 ST1100
91 ST1100Comment
Either one Dean. The only issue I've seen is the surrounding casting on SOME of the XS's and the overall outside diemension of the auto adjuster can cause one to think it is tightened and seated only to see an oil leak which indicates it isn't. Just going back and re-tightening the allen bolts seating it solves that problem. The original allen bolts ARE a bit too long and if possible use the allen bolts that may come with tensioner. Otherwise 3/16-1/4" must be cut off the original bolts as the threaded holes ARE a "bottom" hole. The difference in casting thickness can be seen with the good pics that James put up on this thread of the two adjusters aside each other. Didn't run into this issue on my Venturer, but on two more XS's(3-Phase & a neighbor friend) that I was present when the swap was made apparently had the shoulder of the recessed area not quite as finely finished as some......just my experience......81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Nope, nobody has come back with any wear issues, just mentioned that for the more paranoid among us...
Both seem to work equally well, there's just a bit more fiddlin' on install with the Vision CCT...Fast, Cheap, Reliable... Pick any two
The V-Max and the Venturer are straight bolt on. It is def. necessary to shorten the allen bolts, or better still use shorter bolts, because the casting on the auto CCT is thinner. I had to do that. If you go and use the originals, there is a definite likelihood that you'll strip the threads when you come to tighten up fully.
I used clear bathroom silicone sealer on the gasket face after cleaning both gasket faces and degreasing them. Just a thin smear. No problems with it at all, I've found.
I can't say I noticed any abnormal wear on the top chain guide when I did the shims. The spring tension is stronger but not by much and I'm betting it doesn't matter at all.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
You can post links, but the site won't accept attachments. Best bet is to convert it to a photo, then upload it to a 'open' photo-hosting site like photobucket, then provide a link in your post to the pic.Fast, Cheap, Reliable... Pick any two
Gotcha Crazy Steve.
For the element of clarity, below is a copied line from the FAQ's when I do a search for "attachments"...
"The administrator may allow you to use the attachment feature of this forum, which gives you the ability to attach files of certain types to your posts. This could be an image, a text document, a zip file etc. There will be a limit to the file size of any attachments you make, as the forums should not be used as an extension of your hard disk!"
For clarification, it appears attachments are an option, otherwise what is the purpose of the messages "you may post new threads", "you may post replies" "you man not post attachments" and "you may edit posts".
That along with the quote from FAQ's seems to indicate it is a possibility.Howard
ZRX1200
Seca 750Comment
Hey Howard,
Sorry, but due to limited server space and bandwidth, etc., the attachments option has not be activated, and won't be. Also, we tried to turn it on, but it never worked anyways...Open Source Code for the site!
So...regrettably, as Steve stated, just convert it into a JPG, or just take a photo of it in JPG format, and put it on a photo hosting site....ie. photobucket, and then you'll be able to link to that site on here, either as a LINK, or even an embedded photo that will show in the post!
T.C.T. C. Gresham
Another option is to print it and then scan it. Then you can upload it to Photobucket or whatever photo hosting site you use. Just sayin'
☮Comment
