When I got my XJ the carbs were really crapped up.Frozen tight. Scored a set on Ebay cheap. Looked really clean. Decided to try the Yam carb cleaner that mixes with gas on the original carbs. Best thing I ever used. they are on it now. My go to preferred. Hands down.
Pine sol carb clean on 79xs1100fs
That might work, just keep flushing, well, the last solution was a tad too strong for aluminum, kept my eye on it and was starting to turn it white, nutralized it and washed it heavily. I've got the interneals clean with carb cleaner, I want to shine the outside up a little?? I keep trying to find an inexpensive way, and by the time I'm done, could have bought brand new carbs..lol81 XS1100HComment
I've done the PineSol thing many times with great results. Agree with Steve that it is best to remove all rubber parts including the starter jet shaft. I generally break down the set which can be a PIA but it does keep everything right. If you choose not to remove these parts then you need to be really careful to remove all the PineSol to be sure things don't get gummed up. Work the starter jet shaft back and forth a bunch and put in some silicone to keep the shaft lubed.
I'm a real advocate but do it right.1995 KZ100P
Pods, jets, pipes, cam adjuster, oil cooler
1977 Ironhead - custom build
Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.Comment
WOW. What do YOU polish with?'81 XS1100 SH
Sep. 12th 2015
RIPComment
Whatever you do, don't use vinegar to clean your carbs.
What is wrong with using carburetor cleaner? The stuff isn't even expensive.Marty (in Mississippi)
XS650EComment
This seems like a good option for the outside of the carbs, haven't tried it myself, I paint my carbs....
http://www.aircooledtech.com/tools-o.../soda_blaster/2H7 (79) owned since '89
☮Comment
That has to be one of the best follow up post I've yet to receive on this forum, you guys are awesome, and I'm going to give this a try. I might even make a sand blasting style enclosure, plywood/plexiglass that I have laying around. so it doesn't create a cloud and end up on everything. But a super Thanks! on this idea. Love suggestions that come with photos and how to's. Don't get me wrong, don't want to sound ungrateful for other suggestions, just Evey once in a while, out of the park it goes. I've heard other post mention something about soda blasting, but never new what they were talking about and dummy me never asked. So simple!!81 XS1100HComment
I think I'm in love with that low-tech blaster....I just got my bike a couple of days ago, and it's been sitting for a couple of years so the carbs will have to be gone through. I can't wait to try this idea...My Special is as old as I am.Comment
that soda blaster also works really well
for cleaning up sparkplugs.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
[url]http://www.youtube.com/watch?v=3pA8dwxmAVA&feature=mfu_in_order&list=UL[/url]Comment
jat,
just becareful with the soda's over spray
u dont want it getting on any polished alloy
surface.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
i meant the overspray, if ur bike has
polished covers etc dont get any overspray
of the bicarb on the parts, that stuff gets every where.Last edited by petejw; 12-11-2011, 07:03 PM.pete
new owner of
08 gen2 hayabusa
former owner
zrx carbs
18mm float height
145 main jets
38 pilots
