Originally posted by petejw
View Post
Pine sol carb clean on 79xs1100fs
Originally posted by petejw View Posti meant the overspray, if ur bike has
polished covers etc dont get any overspray
of the bicarb on the parts, that stuff gets every where.
For cleaning aluminium objects, the use of sodium bicarbonate is discouraged as it attacks the thin unreactive protective oxide layer of this otherwise very reactive metal.
T.C.T. C. Gresham
idle mixture screws
Originally posted by dpotter58 View PostI'm working on a set that came apart relativly easy except the idle mix screws. The slots in the screw heads were pretty much gone so after 4 days of soaking with deep creep i used the dremel, cut down to the screws, re-slotted them and they are still not coming out...1980 xs1100sg
here's a trick I invented (or perhaps re-invented).
Get a screwdriver bit that fits the needle slot real good and put it in a drill press.
Unplug the drillpress, this is a manual thing.
Put the carb body on the drill press baseplate, use the drill feed handle to force the drill bit hard down into the needle's screwdriver slot.
While keeping the screwdriver bit hard down into the slot turn the drill chuck by hand to turn the needle out.
Works most of the time.
Good luck.Fred Hill, S'toon
