Pine sol carb clean on 79xs1100fs
  • SFerinTEXAS
    • Jun 2006
    • 877
    #46
    When I got my XJ the carbs were really crapped up.Frozen tight. Scored a set on Ebay cheap. Looked really clean. Decided to try the Yam carb cleaner that mixes with gas on the original carbs. Best thing I ever used. they are on it now. My go to preferred. Hands down.
    79SF
    XJ11
    78E
    • old_skool
      • Nov 2011
      • 554
      • Ohio
      #47
      That might work, just keep flushing, well, the last solution was a tad too strong for aluminum, kept my eye on it and was starting to turn it white, nutralized it and washed it heavily. I've got the interneals clean with carb cleaner, I want to shine the outside up a little?? I keep trying to find an inexpensive way, and by the time I'm done, could have bought brand new carbs..lol
      81 XS1100H
      • Aches n Pains
        • 349
        • Reston, Va.
        #48
        I've done the PineSol thing many times with great results. Agree with Steve that it is best to remove all rubber parts including the starter jet shaft. I generally break down the set which can be a PIA but it does keep everything right. If you choose not to remove these parts then you need to be really careful to remove all the PineSol to be sure things don't get gummed up. Work the starter jet shaft back and forth a bunch and put in some silicone to keep the shaft lubed.
        I'm a real advocate but do it right.
        1995 KZ100P
        Pods, jets, pipes, cam adjuster, oil cooler
        1977 Ironhead - custom build
        Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
        Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
        • 81xsproject
          • 3185
          • Fortuna, CA
          #49
          WOW. What do YOU polish with?
          '81 XS1100 SH
          Sep. 12th 2015
          RIP
          • MacMcMacmac
            • Dec 2006
            • 127
            • Ottawa, Canada
            #50
            Whatever you do, don't use vinegar to clean your carbs.
              What is wrong with using carburetor cleaner? The stuff isn't even expensive.
              • old_skool
                • Nov 2011
                • 554
                • Ohio
                #52
                Most of us know I guess carb cleaner for the inside and the grime on the outside, we're all looking for that "quick shine" in a bottle without having to disassemble the entire carb bank
                81 XS1100H
                  • 8962
                  This seems like a good option for the outside of the carbs, haven't tried it myself, I paint my carbs....
                  http://www.aircooledtech.com/tools-o.../soda_blaster/
                  • old_skool
                    • Nov 2011
                    • 554
                    • Ohio
                    #54
                    That has to be one of the best follow up post I've yet to receive on this forum, you guys are awesome, and I'm going to give this a try. I might even make a sand blasting style enclosure, plywood/plexiglass that I have laying around. so it doesn't create a cloud and end up on everything. But a super Thanks! on this idea. Love suggestions that come with photos and how to's. Don't get me wrong, don't want to sound ungrateful for other suggestions, just Evey once in a while, out of the park it goes. I've heard other post mention something about soda blasting, but never new what they were talking about and dummy me never asked. So simple!!
                    81 XS1100H
                    • JasonRedbeard
                      • 109
                      • Tuscaloosa, AL
                      #55
                      I think I'm in love with that low-tech blaster....I just got my bike a couple of days ago, and it's been sitting for a couple of years so the carbs will have to be gone through. I can't wait to try this idea...
                      My Special is as old as I am.
                      • petejw
                        • 2269
                        • sydney australia
                        #56
                        that soda blaster also works really well
                        for cleaning up sparkplugs.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        1981 xs1100 RH (aus) (5N5)
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • old_skool
                          • Nov 2011
                          • 554
                          • Ohio
                          #57
                          can't wait to try, I'm syked
                          81 XS1100H
                          • petejw
                            • 2269
                            • sydney australia
                            #58
                            jat,
                            just becareful with the soda's over spray
                            u dont want it getting on any polished alloy
                            surface.
                            pete
                            new owner of
                            08 gen2 hayabusa
                            former owner
                            zrx carbs
                            18mm float height
                            145 main jets
                            38 pilots
                            • old_skool
                              • Nov 2011
                              • 554
                              • Ohio
                              #59
                              Originally posted by petejw
                              jat,
                              surface.
                              such as?? I'm going to use it on the carb bodies, what are you warning of??
                              81 XS1100H
                              • petejw
                                • 2269
                                • sydney australia
                                #60
                                i meant the overspray, if ur bike has
                                polished covers etc dont get any overspray
                                of the bicarb on the parts, that stuff gets every where.
                                pete
                                new owner of
                                08 gen2 hayabusa
                                former owner
                                zrx carbs
                                18mm float height
                                145 main jets
                                38 pilots
