hi XS1100_OEM4ME,
"I know it is after the fact, but before honneing, you should use a ridge reamer"
i agree with u totally, other than the ridge reaming and ball honing
i did exactly as u mentioned, not my first engine rebuild either.
i did mention the ridge reamer in an earlier post,
i did this job on the cheap and wanted to use what i already had,
i had the cylinder honer, the honing balls arent really necessary, they
do help with the running in of the rings sooner and give a finer cross hatch,
its not a necesity and using the stones isnt a problem,
a ridge reamer is usally used to remove carbon
Everyone has their own way of comming up with the same result, a great running motor
I am guessing you used the honeing stones in such a way to put all the presure on the ridge till it was gone, then finished the hone of the walls and i am sure she runs great
