cylinders honed
  • petejw
    • 2269
    • sydney australia
    cylinders honed
    honed the cylinders today
    and gapped the over size rings
    came out pretty good.
    heres a few pics.
    the 3rd cylinder slightly honed in a attempt to show the depth of the upper ridge
    the cylinder honed, removing the upper ridge.
    the pistons cleaned and polished
    pete
    new owner of
    08 gen2 hayabusa
    former owner
    1981 xs1100 RH (aus) (5N5)
    zrx carbs
    18mm float height
    145 main jets
    38 pilots
    Again, you do better work than I!
    • DAVINCI
      • Jan 2011
      • 1048
      • Cedar Mountain, NC
      Hey, Pete, are those NEW pistons??
      • petejw
        • 2269
        • sydney australia
        thanx nate,
        i ended up taking a bit of the the bores, i didnt want that
        upper ridge left there.
        hey davinci,
        there off my original engine, theyve got
        over 140,000k's on them, they cleaned up pretty well
        considering, there was a fair bit of carbon on them.
        pete
        new owner of
        08 gen2 hayabusa
        former owner
        zrx carbs
        18mm float height
        145 main jets
        38 pilots
        • Rickrod3
          • Jun 2009
          • 721
          • Oakland, New Jersey
          Originally posted by petejw
          thanx nate,
          hey davinci,
          Hey Pete:
          Nice work. How did you clean the pistons?
          I have been using a wire wheel in a hand grinder to clean up some cases.
          It didn't seem to rough on them so, I was thinking of using it on some pistons which need cleaning.
          Rick
          650SF
          XS1100SG Project bike
          • petejw
            • 2269
            • sydney australia
            thanx rick,
            for the ring grooves, i broke an old ring and used that to
            clean the grooves,
            i used a wire wheel (worn/used) on the grinder gently
            for the tops of the pistons,
            inside the pistons i used oven cleaner, this stuff is strong
            so i let it sit for 5-10 min before rinsing but needed to do
            it a couple of times then used a scourer.
            for the oil holes (there was a few that were blocked) i used
            a small drill bit that fitted neatly inside the hole.
            i then used a buffer to polish the tops and sides,
            overkill? probably but turned out pretty good and hopefully will prevent carbon from sticking.
            pete
            new owner of
            08 gen2 hayabusa
            former owner
            zrx carbs
            18mm float height
            145 main jets
            38 pilots
            • Rickrod3
              • Jun 2009
              • 721
              I've heard of polishing piston tops before. It makes sense that it would prevent carbon build up.
              So I don't think it over kill.
              Rick
              650SF
              • petejw
                • 2269
                • sydney australia
                yep, same thing as polishing the exhaust ports.
                pete
                new owner of
                08 gen2 hayabusa
                former owner
                zrx carbs
                18mm float height
                145 main jets
                38 pilots
                • foreda
                  • 949
                  • Southwest Louisiana
                  Rings
                  Did you use oversize rings and grind the ends?
                  78 XS1100E Standard
                  Coca Cola Red
                  Hooker Headers
                  1979 XS1100 Special
                  1980 XS Standard
                  2006 Roadstar Warrior
                  • petejw
                    • 2269
                    • sydney australia
                    yep, bought the .25 oversize rings off ebay
                    around $40 from memory, probably wasnt a
                    bad idea either, i ended up taking a fair bit of the bore.
                    pete
                    new owner of
                    08 gen2 hayabusa
                    former owner
                    zrx carbs
                    18mm float height
                    145 main jets
                    38 pilots
                      Did you really have to file much off the ring even though?
                      • petejw
                        • 2269
                        • sydney australia
                        before i honed it the rings sat over each other,
                        after the hone, the rings butted together,
                        i set the ring gap at 10 thou, but u need to be careful
                        the 1st one i did i took a bit more off than i wanted to,
                        the gap is 8 thou - 16 thou but max wear was
                        1mm i think from memory.
                        do the oil rings first and do a little at a time, it doesnt take
                        much and be sure the ends are square, i used a points file
                        holding the ring in my hand pushing the ring together to do that.
                        once u do a cpl it does get easier.
                        i also used a piston with the number2 compression ring fitted
                        and pushed that into the cylinder to square the ring in its bore
                        to check the end gap.
                        when u honed the cylinders did u remove the top ridge, its best
                        to do so, if u dont u can run the risk of the top ring breaking.
                        pete
                        new owner of
                        08 gen2 hayabusa
                        former owner
                        zrx carbs
                        18mm float height
                        145 main jets
                        38 pilots
                        • petejw
                          • 2269
                          • sydney australia
                          nate,
                          i also used the dremel with a flat sanding disc
                          to take the initial part of the ring off before using
                          the points file, but if u dnt feel comfortable just use
                          a file.
                          pete
                          new owner of
                          08 gen2 hayabusa
                          former owner
                          zrx carbs
                          18mm float height
                          145 main jets
                          38 pilots
                            Isn't there a problem with polishing the sides of the pistons? IIRC, pistons have a specific machined finish on them designed to hold oil for lubrication. Not enought oil, you get scuffed bores/pistons....
                              I ask cause the 1st over rings are only .25mm larger correct, so shouldnt be much material to remove.
                              Also IIRC last time I looked at the rings I got I don't think there was any difference between the top two rings, did you find anything?
