MikesXS emulators
    • 8798
    Originally posted by natemoen
    I gotta ask then....how is it then that the 35mm emulator work for 37mm forks?
    Ok, like Chris said, the emulators sit on top of the damping rod, they don't slip down in the recess. They fit fine on the Special damping rods, but looking at the Standard damping rods, I don't think they will fit as well, not as much surface area. Here is a comparison of the 2 damping rods....
      So your saying its kinda a crapshoot as to whether or not I can get them to work in my standard...
        • 8798
        Yes it is, but someones gotta try it. I would try it, but I don't have a bike that uses Standard forks anymore, my Standard has FJ forks. Problem is, if it doesn't work, you've already ruined your damper rods by drilling them out, it's non reversible.
          Yes it is, but someones gotta try it. I would try it, but I don\\\'t have a bike that uses Standard forks anymore, my Standard has FJ forks. Problem is, if it doesn\\\'t work, you\\\'ve already ruined your damper rods by drilling them out, it\\\'s non reversible.
          I dont have the funds or the extra set of forks to experiment on, otherwise I would
          Do you have a spare set of standard forks to donate to the cause
            • 8798
            Why yes I do have an extra set of damper rods for the 78-79 Standard I can donate. You wouldn't need the whole fork assy, just the rods. Go for it.
              Perhaps I will do it this winter, but if it doesn\'t work I am coming after you for that donation
                • 8798
                Sounds good. Happy Guru status, Nate.
                  Thanks, too bad I still dont know jack sh**
                  I have kinda been post whoring to get that 20 or so I needed for it today.
                  • Cobia
                    • Jul 2007
                    • 1587
                    • Palm Beach County, Fl
                    Hey Nate,
                    Let me know if it works so I can do it to my G. I like a stiffer suspension.
                    1980G Standard, Restored
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    1980GH Special, Restored
                    '82 XJ1100 (Sold)
                      Originally posted by Cobia
                      Hey Nate,
                      It will definitely be a few months, before anything happens.
                        If I can fit them into my budget, I may well mod my spare forks over the winter, since I need to pull them apart and replace the seals anyways, I may as well tear them down and go through them and see if the emulators will fit them properly (I'm thinking I can test fit the emulators in there before drilling them to make sure they fit in there properly). Then I can swap back and forth, and with mine being an 80, we can see how they work both with and without air on top of them.
                          Ooooo someone else to be the guinea pig! I like!
                          • yamahansolo
                            • Aug 2007
                            • 1113
                            • jawga
                            Ok. I have air caps on mine and racetech said no air. I left it empty. My forks are standard and the look like the previous picture the emulators will slide around on it mine did.
                            If someone could just get the diameter of the emulators we would know. I bet they are the same. I am just curious as to why 6 holes on mikes and not 4 like racetech?
                            79 xs11 standard
                            8mm msd wires
                            tkat fork brace...
                            Fox shocks...
                            mikes650 front fender
                            led's gallore...
                            renthal bars
                            gold valve emulators
                            vmax tensioner
                            Rifle fairing
                              Do you remember what all the measurements were on your emulators?
                                • 8798
                                Chris, the way I look at it is, the more holes, the less chance of the old compression circuit causing any restriction. The old circuit must be fully disabled for the emulators to work correctly. Then again, more holes will slightly weaken the damping rod. Mike's recommends 15W oil, so maybe the reason for more holes. If you are using thin oil such as 5 or 10W, less holes probably won't be an issue. I'm running 20 in mine with a single 1/16" rebound hole (hole near top of rod on the side).
                                I'll pop one of my emulators out this weekend and measure the diameter.
