Originally posted by natemoen
View Post
MikesXS emulators
So your saying its kinda a crapshoot as to whether or not I can get them to work in my standard...Nathan
Originally posted by natemoen View PostSo your saying its kinda a crapshoot as to whether or not I can get them to work in my standard...2H7 (79) owned since '89
Originally posted by bikerphil View PostYes it is, but someones gotta try it. I would try it, but I don\\\'t have a bike that uses Standard forks anymore, my Standard has FJ forks. Problem is, if it doesn\\\'t work, you\\\'ve already ruined your damper rods by drilling them out, it\\\'s non reversible.
Do you have a spare set of standard forks to donate to the causeNathan
Originally posted by natemoen View PostI dont have the funds or the extra set of forks to experiment on, otherwise I would
Do you have a spare set of standard forks to donate to the cause2H7 (79) owned since '89
Perhaps I will do it this winter, but if it doesn\'t work I am coming after you for that donationNathan
Originally posted by bikerphil View PostSounds good. Happy Guru status, Nate.
I have kinda been post whoring to get that 20 or so I needed for it today.Nathan
Hey Nate,
Let me know if it works so I can do it to my G. I like a stiffer suspension.1980G Standard, Restored
Kerker 4 - 1
850 Rear End Mod
Automatic CCT
1980GH Special, Restored
'82 XJ1100 (Sold)
Originally posted by Cobia View PostHey Nate,
Let me know if it works so I can do it to my G. I like a stiffer suspension.Nathan
If I can fit them into my budget, I may well mod my spare forks over the winter, since I need to pull them apart and replace the seals anyways, I may as well tear them down and go through them and see if the emulators will fit them properly (I'm thinking I can test fit the emulators in there before drilling them to make sure they fit in there properly). Then I can swap back and forth, and with mine being an 80, we can see how they work both with and without air on top of them.Cy
Originally posted by cywelchjr View PostIf I can fit them into my budget, I may well mod my spare forks over the winter, since I need to pull them apart and replace the seals anyways, I may as well tear them down and go through them and see if the emulators will fit them properly (I'm thinking I can test fit the emulators in there before drilling them to make sure they fit in there properly). Then I can swap back and forth, and with mine being an 80, we can see how they work both with and without air on top of them.Nathan
Ok. I have air caps on mine and racetech said no air. I left it empty. My forks are standard and the look like the previous picture the emulators will slide around on it mine did.
If someone could just get the diameter of the emulators we would know. I bet they are the same. I am just curious as to why 6 holes on mikes and not 4 like racetech?" She'll make point five past lightspeed. She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. "
79 xs11 standard
8mm msd wires
tkat fork brace...
Fox shocks...
mikes650 front fender
led's gallore...
renthal bars
gold valve emulators
vmax tensioner
Rifle fairing
Originally posted by yamahansolo View PostOk. I have air caps on mine and racetech said no air. I left it empty. My forks are standard and the look like the previous picture the emulators will slide around on it mine did.
If someone could just get the diameter of the emulators we would know. I bet they are the same. I am just curious as to why 6 holes on mikes and not 4 like racetech?Nathan
Chris, the way I look at it is, the more holes, the less chance of the old compression circuit causing any restriction. The old circuit must be fully disabled for the emulators to work correctly. Then again, more holes will slightly weaken the damping rod. Mike's recommends 15W oil, so maybe the reason for more holes. If you are using thin oil such as 5 or 10W, less holes probably won't be an issue. I'm running 20 in mine with a single 1/16" rebound hole (hole near top of rod on the side).
I'll pop one of my emulators out this weekend and measure the diameter.2H7 (79) owned since '89
