MikesXS emulators
  • Toolmaker Tim
    • 671
    • South Bend, Indiana
    #76
    So basicly the spacer would be a cup that the emulator sat in, and had an opening in the bottom for oil to flow through.
    1979XS1100SF
    K&N's and drilled airbox
    Jardine 4in1
    Dunlop Elite 3's
    JBM slide diaphragms
    142.5 main jets
    45 pilot jets
    T.C.'s fusebox & SOFA
    750/850 FD mod.
    XV 920 Needle Mod.
    Venture Cam Chain Tensioner
    • yamahansolo
      • Aug 2007
      • 1113
      • jawga
      #77
      I also posted this earlier... I have a standard and the kit ssays to "not" use the spacer in the standard. The race techs. Were 150 not 250. I used the stock springs uncut. The. Racetech guys said I need 1 inch of preload. With the racetch emulators (not mikes) the stock springs on the standard stick out exactly 1 inch. So no other springs needed. I need to pull mine out because I think they were 20mms or so I didn't think they were 27 but it was a last year that I put themin... even with the stock old springs I am very capable of keeping up with my friends on sportbikes!
      79 xs11 standard
      8mm msd wires
      tkat fork brace...
      Fox shocks...
      mikes650 front fender
      led's gallore...
      renthal bars
      gold valve emulators
      vmax tensioner
      Rifle fairing
      • yamahansolo
        • Aug 2007
        • 1113
        • jawga
        #78
        Now that I think about it and with a ruler to reference it they were probobly the same as marty's. They were just a tad bigger than an inch which as you all know is 25.4mm
        79 xs11 standard
        8mm msd wires
        tkat fork brace...
        Fox shocks...
        led's gallore...
        renthal bars
        vmax tensioner
        Rifle fairing
          What is the diameter of the XS650 emulator?
          MikesXS emulator 23.5MM diameter.
          • Toolmaker Tim
            • 671
            #80
            How tall is the body of the Mike's XS emulator?
            1979XS1100SF
            Jardine 4in1
            Dunlop Elite 3's
            142.5 main jets
            45 pilot jets
            750/850 FD mod.
            XV 920 Needle Mod.
              It is 14MM tall.
                The RaceTech emulator is also 14 mm tall.
                • greatnw
                  • 177
                  #83
                  Hi guys, I'm following this discussion and was searching around for other brand options.
                  I found this option for harleys at JP Cycles for $40.
                  Anyone got any experience with it?
                  http://www.jpcycles.com/product/230-881
                  Bothell, WA
                  1980 XS1100SG
                    #84
                    Those are for 41mm HD forks and are way too large to fit into the XS 37mm forks.
                    Might be a nice fit in the 41mm FJ forks though...
                    • greatnw
                      • 177
                      #85
                      Figured that was the case but didn't know. You guys are amazing with your level of expertise on the nuances of these great bikes.
                      Bothell, WA
                      1980 XS1100SG
