rubber circles inbetween cooling fins??
XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model. -
USA eBay # 200569710410
The local hard ware did not have O-rings to fit the valve covers on an XS650 I was working on 17 years ago. The owner saw what I was asking for and got out some spools of this stuff, he asked if he could cut the stock O-ring I had, measured and cut a length off the spool super glued it together. I never used it but could in a pinch.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'eComment
The stuff I got is solid...even better for the fin jobXS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Last edited by motoman; 11-12-2014, 05:18 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
James,
Your photo shows the correct number of "Viton chunks" on the left side (12), but it appears you mounted them starting one row "too high".
Simply remove the 2 on the top "row", and mount them in the "row" directly under the bottom "row" you currently have chunks in, and it will be as it came from the factory ... hope that makes sense!
Can't see the right side of your engine, but you can use this photo to make sure they are mounted in the correct positions on the right side ... P.S. Supersize the photo!
1979 Honda CBX
2002 Kawasaki ZRX1200R
WE MISS YOU, DONComment
Different thickness?
P.S.S. The "new bottom row" chunks you install (on engine's left side) may have to be a slightly different thickness than the chunks you have in your current "top row" ...
You may have to cut new ones ...
1979 Honda CBX
Thanks Marco. I'll do just that. The ones on the right side are correct and less easy to get wrong because of the cam plug things. Gotta get things right, eh?XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Marco
1979 Honda CBX
Funny you mentioned those head nuts ... I was wondering why you chose that style ...
By the way, I've been accused more than once of living in that same OCD universe!
Marco
1979 Honda CBX
They were on eBay as for the xs1100. The washers were so huge they wouldn't fit and the nuts had points. I'll be putting the OEM ones back on!
Yeah, the OCD world. We're all on the spectrum somewhere, I reckonXS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
Actually, I have CDO ... same as OCD, but with the acronym letters arranged in alphabetical order ... just as they should be!
+1 on going back to the OEM head nuts ...
Marco
1979 Honda CBX
Or should that be EMO head nuts? ... oh, forget it ... don't mind me, it's just my "CDO" rearing it's head again ...
Marco
1979 Honda CBX
