rubber circles inbetween cooling fins??
  • James England
    • 3039
    • North of England
    #46
    I wonder why they shrunk ?
    You can swell some rubber like parts with fuel or acetone, once swelled would they stay that way ? Does the heat of the engine keep them from shrinking, would it keep the ones that were swelled with acetone from shrinking back ?
    The Viton cord ought to solve it. The originals shrank so much they were totally useless. I've spandex parts before using another chemical but they always shrink back again. Hopefully the Viton will do the trick.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      #47
      I got it on eBay. It's Viton cord...
      http://www.ebay.co.uk/itm/2306991448...%3AMEBIDX%3AIT
      USA eBay # 200569710410
      The local hard ware did not have O-rings to fit the valve covers on an XS650 I was working on 17 years ago. The owner saw what I was asking for and got out some spools of this stuff, he asked if he could cut the stock O-ring I had, measured and cut a length off the spool super glued it together. I never used it but could in a pinch.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • James England
        • 3039
        • North of England
        #48
        The stuff I got is solid...even better for the fin job
          looks to be a good DIY replacement. Wouldn't want those fins flappin' in the breeze. Still missin' one lower.....for whatever reason, the bottom two fins didn't have them, least my Venturer never did.
          • James England
            • 3039
            • North of England
            #50
            you, or me? Have I missed some? Gotta get it right!
            • Prisoner6
              • Aug 2013
              • 1184
              • Phoenix, AZ
              #51
              ... Have I missed some? Gotta get it right!
              James,
              Your photo shows the correct number of "Viton chunks" on the left side (12), but it appears you mounted them starting one row "too high".
              Simply remove the 2 on the top "row", and mount them in the "row" directly under the bottom "row" you currently have chunks in, and it will be as it came from the factory ... hope that makes sense!
              Can't see the right side of your engine, but you can use this photo to make sure they are mounted in the correct positions on the right side ... P.S. Supersize the photo!
              Marco
              1979 Honda CBX
              2002 Kawasaki ZRX1200R
              WE MISS YOU, DON
              • Prisoner6
                • Aug 2013
                • 1184
                • Phoenix, AZ
                #52
                Different thickness?
                P.S.S. The "new bottom row" chunks you install (on engine's left side) may have to be a slightly different thickness than the chunks you have in your current "top row" ...
                You may have to cut new ones ...
                Marco
                1979 Honda CBX
                WE MISS YOU, DON
                • James England
                  • 3039
                  • North of England
                  #53
                  Thanks Marco. I'll do just that. The ones on the right side are correct and less easy to get wrong because of the cam plug things. Gotta get things right, eh?
                  • James England
                    • 3039
                    • North of England
                    #54
                    Yep, I needed to cut new ones...fortunately, having a metre of the stuff helps......this better?
                    • Prisoner6
                      • Aug 2013
                      • 1184
                      • Phoenix, AZ
                      #55
                      Aaaahh, yes ...
                      Marco
                      1979 Honda CBX
                      WE MISS YOU, DON
                      • James England
                        • 3039
                        • North of England
                        #56
                        Aaaahh, yes ...
                        Phew, all is now well in my OCD universe......
                        I don't like the stainless head nuts I just put on. Too pointy. I'm going to try grinding the points off. Or I'll clean up the OEM ones and get them chromed or zinc plated......
                        • Prisoner6
                          • Aug 2013
                          • 1184
                          • Phoenix, AZ
                          #57
                          Funny you mentioned those head nuts ... I was wondering why you chose that style ...
                          By the way, I've been accused more than once of living in that same OCD universe!
                          Marco
                          1979 Honda CBX
                          WE MISS YOU, DON
                          • James England
                            • 3039
                            • North of England
                            #58
                            They were on eBay as for the xs1100. The washers were so huge they wouldn't fit and the nuts had points. I'll be putting the OEM ones back on!
                            Yeah, the OCD world. We're all on the spectrum somewhere, I reckon
                            • Prisoner6
                              • Aug 2013
                              • 1184
                              • Phoenix, AZ
                              #59
                              Actually, I have CDO ... same as OCD, but with the acronym letters arranged in alphabetical order ... just as they should be!
                              +1 on going back to the OEM head nuts ...
                              Marco
                              1979 Honda CBX
                              WE MISS YOU, DON
                              • Prisoner6
                                • Aug 2013
                                • 1184
                                • Phoenix, AZ
                                #60
                                Or should that be EMO head nuts? ... oh, forget it ... don't mind me, it's just my "CDO" rearing it's head again ...
                                Marco
                                1979 Honda CBX
                                WE MISS YOU, DON
