Originally posted by petejw
View Post
rubber circles inbetween cooling fins??
'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
The fins are simply a heat sink, designed to increase the surface area to dissapate the heat from the cylinder. The rubbers are there to dampen vibration and deaden noises from the fins and engine. The longer the fin the greater the need. Short fin engines are generally happy without them, longer fin engines, in particular 2 smokes, can be horrendously noisy without them. I've had engines in the past without them with no noticeable difference, OTH i've had other engines where it's been very noticable. I've never seen a fin break without them due to vibration but I guess it's entirely possible.1980 SG. (Sold - waiting on replacement)
Yeah I agree that the fins are safe on the XS11 without the dampers, but I have seen 2 strokes lose fins to stress cracks created by vibration.
Yamaha KT100 Kart engines are notorious for it, and you have to be fairly diligent in looking for them and drilling the end point of the crack to prevent it continuing. They also tend to start at the intake and exhaust where the fins are often squared off and have right angles which tend to lead to cracks more than the rounded edges everywhere else.Guy
'78E
i probably could of put it better,
in that the fins are there to dissipate
heat away from the cylinders,
"The vibration of the fin is undesired and will not necessarly increase or decrease the cooling ability of the engine."
sorry i dnt know how to quote,
but i dont agree with this, -
When an air cooled engine is stationary and running the vibration of the
fins assist air flow preventing the engine from overheating.
the best way i could describe it, would be like moving your hand up and down really fast, try it and youll feel the air move around your hand.pete
new owner of
08 gen2 hayabusa
former owner
1981 xs1100 RH (aus) (5N5)
zrx carbs
18mm float height
145 main jets
38 pilots
the best way i could describe it, would be like moving your hand up and down really fast, try it and youll feel the air move around your hand.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
+1 what WMarshy said! Vibration for improved cooling......now that's funny, don't care who you are!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Originally posted by 79XS11F View PostDon't chuck them. They dampen sound and prevent fin vibration caused by the air that is forced through the fines at highway speeds. Take a photo of their location and remove them. They are just wedged in place but do pay attention to them so they go back into their original positions. They are of DIFFERENT thicknesses and will not wedge back into place as intended if you mix them up. Try removing all the top ones and bag & label them followed by each set going downward.
Rob....has absolutely nothing to do with there purpose! They are there to absorb the harmonics from the vibration ONLY.
Originally posted by MattWood View PostHarmonics can kill a perfectly good piece of metal. If the engineers bothered to waste their time designing some pieces of rubber in the heads, there must have been a really good reason for it.....but those could be 'unobtanium' in some parts of the country.....
Last edited by motoman; 08-21-2014, 05:58 PM.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
another 2cents
Does the term "fin ringing"mean anything to you?
As previously mentioned...The longer the fins for cooling purposes,more sound is transferred to those fins ....Hence the term "dampers"as they are known by.78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.
dampeners
I've removed them from all my bikes, makes no difference at all in sound or vibration. No fins have cracked in the time I've been riding them. If anyone need some PM me I have five sets here.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186
I pulled mine out for the recent engine work, didn't bag them up (except in one bag) and have been fiddling about trying to get the right ones in up right places!
I'd keep them. They are there for a reason and the Japanese usually were pretty thorough design-wise. I intend sorting mine out and putting them all back. I'm trying to find a closeup engine shot of how they were arranged as I do remember it looked kinda nice in a curve downwards, each side of huge plug...
Also, I'm obsessed by trying to keep them at leastlooking as standard as possible but improved...if you see what I mean.
Ps does anyone have a closeup pic of the head from the side, complete with rubber bits? I can't find mine in the thousands of pix I have!!Last edited by James England; 08-24-2014, 04:42 PM.XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.
Originally posted by James England View PostI pulled mine out for the recent engine work, didn't bag them up (except in one bag) and have been fiddling about trying to get the right ones in up right places!
Ps does anyone have a closeup pic of the head from the side, complete with rubber bits? I can't find mine in the thousands of pix I have!!81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
