Gas Cap Seal Replacement
    • 2117
    Some rubber reacts to acetone very funny-it will either swell up,dissolve,or stay the same.I think acetone is more hazardous than fuel-and more flammable!
    • res1uqtp
      • May 2009
      • 84
      • East Central IL
      Well not sure how well this will hold up but since I'm rebuilding two of these machines I picked up two of them today. FANTASTIC MOD!!!!!!!! Fit's perfect .. seals well.
      And at 1.99 /ea it doesn't have to last another 30 years. You can buy a whole box of them for what the oem replacement cost. Even the one mixesxs sells is $8 bucks and shipping.
      Good find my man ....
      My Stable:
      2006 Triumph Bonneville Black
      1979 Yamaha XS11 Special (2 of them)
      1982 Yamaha XS400 Heritage Special
      1981 Suzuki GS550 E
      1976 Honda CB550F Supersport
      • DenyP
        • 599
        • Staples, Minnesota 56479
        Have you ever made the mistake of using vacuum hose for gas line? Very few rubber compounds stand up to todays gas. If your tanks are painted with polyurethane paint, then all you will need to consider is your crotch. I would recommend tossing one of those thermostat gaskets in a container of gas and let it soak for a day or so to see if it will hold up. J.M.H.O.
        Deny
          #34
          Originally posted by latexeses
          Thanks DGXSER,
          That part of the fiddling is coming up on my bike. However, do you think that gasket fit the standard cap?
          Hi late,
          the tank seal from MikesXS fits the Special and the Standard XS11. Most of the cap's innards swap too, including the lock mechanism which is good if you are swapping tanks and don't want to deal with two keys that look just the same. BTW, so that's what those 3 screws are for? I tossed them as serving no useful purpose. My fuel cap teardown showed those inner filter discs to be totally missing. Don't seem to bother the cap any.
          • res1uqtp
            • May 2009
            • 84
            • East Central IL
            #35
            Deny
            reasonable idea .....
            My Stable:
            1981 Suzuki GS550 E
              • 8962
              I picked one of these Fel-Pro thermostat housing gaskets today and I'm gonna soak it in gas for a while and see what happens. BTW, the car application for it is an 85-95 Toyota Camry, 4 cyl.
              • draketrumpet
                • Feb 2010
                • 387
                • Norman, OK
                #37
                Picked up one myself today too, along with some emory cloth for that lovely rust on mine. Anxiously awaiting your results and a lazy weekend afternoon.
                • draketrumpet
                  • Feb 2010
                  • 387
                  • Norman, OK
                  #38
                  Alright, I feel like a new man!
                  Before:
                  In between:
                  After:
                  Tools:
                  That screw driver you see poking out in the last picture
                  A little flat screw driver to help with the clip
                  Emory cloth multi-pak from harbor frieght
                  My hands
                  SWMBO's hands to hold the spring down while I put the clip back on
                  Time:
                  1:20
                  I couldn't get all the rust out as I have no power sander or dremmel tool, but I'm not sure even that would have worked completely. However, there is a whole lot less!
                  Now to put it on and see if the gas tank will stop singing after a quick ride around town!
                    #39
                    A moped? You own a moped?
                    Hi Drake,
                    you ask " 2004 RCM-50GL since 2008 (if you've ever heard of this, please tell me)"
                    I Googled 2004 RCM-50 GL and got 7 hits. This is the first:-
                    Your post above was hit#3.
                      • 8962
                      Ok, I soaked one of these Fel-Pro gaskets in gasoline for a couple of days. No problems, held up fine.
                      • res1uqtp
                        • May 2009
                        • 84
                        • East Central IL
                        #41
                        SAWEET ...
                        now I'm just feeling bold. Let's get some E85 next and see how long it will last
                        My Stable:
                        1981 Suzuki GS550 E
                        • draketrumpet
                          • Feb 2010
                          • 387
                          • Norman, OK
                          #42
                          Corn gas
                          Originally posted by res1uqtp
                          SAWEET ...
                          Can we even run corn gas in our bikes? Anyways, why would you want to limit range even further?
                          • draketrumpet
                            • Feb 2010
                            • 387
                            • Norman, OK
                            #43
                            Hi Drake,
                            Hey thanks.
                            I suppose you might call it a moped, but if you check out my other bike post you'll see it can go a little faster than most mopeds, and it has no pedals.
                              • 8962
                              SAWEET ...
                              Next I'm gonna soak that F'er in some acetone, see how it does.
                                #45
                                Phil,
                                Thanks for running the test. Like i said, I know mine has seen and experienced gasoline and acetone, but not soaked in it. Great to know it is a long term fix though.
                                Drake,
                                some areas are using higher percentages of ehtanol and or E-85 if you want it or not. It is supposed to be much worse than gasoline on such parts.
