No Oil Pressure!!
    #46
    Well, at first I was thinking I really hope I/we are right about this pin, I'd hate to get in there and see all is good. But then he told me that his first test ride, it would not stay in first gear for nothing. I knew it was time for a gear swap/repair and the shaft inspection was just part fo the project. So, I felt alot better about tearing it all back down, again. At this point he should be able to put the pans on in his sleep!
    As to the shaft, it was kind of toast, it had been sliding around and been eaten into by the middle driven gear past that cutout.
    • petejw
      • 2269
      • sydney australia
      #47
      Hey Dgxser,
      I hope you guys get it sorted out,
      and have better luck with the first gear fix.
      I replaced the buggered gears with the gears from
      my seized engine which still looked new and had no problems,
      didnt fix the first gear problem. Still havent got back into it 2 suss it out.
      Let us know how it works out.
      pete
      new owner of
      08 gen2 hayabusa
      former owner
      1981 xs1100 RH (aus) (5N5)
      zrx carbs
      18mm float height
      145 main jets
      38 pilots
      • Varnae
        • Aug 2008
        • 318
        • Noblesville, IN
        #48
        Update
        So just to keep everyone up to date, the oil pressure is now fixed. The problem I'm running into now is that it's backfiring from the left side exhaust. We replaced the coils and that didn't fix the issue. Our suspicion is that the valves need to be shimmed, particularly on the #1 cylinder as that seems to be where it's coming from. We suspect this to be the issue because when we were trying to synch the carbs it repeatedly blew off the tubing on the #1 carb, meaning that it's blowing out that hole instead of sucking in. I'm going to pull the carbs off and give them a good soak and clean because well... it couldn't hurt but we suspect it's not going to do much good either. Doesn't matter though, I could use the experience/learning as far as the carbs go and I'm pretty sure there are still some areas that are gummed up. Once I get the carbs cleaned up we'll see what happens. Still heavily leaning towards a leaking valve though.
        As much as I want to throw some seafoam in the tank and ride it to see if that helps clear things out, I'm not gonna. I'm going to do it up right and clean the carbs real well. I don't want to do any further damage than what I may have already done.
        From what I can tell though, the gears work just fine. I put it in gear and rode it around the block (sorta) so that I could put it back on the trailer to bring it back from Cinci.
        If you don't own a fire extinguisher, do me a personal favor and go purchase one... immediately.
        1980 MNS
          Do you have a gauge to do a compression check? Probaby a good idea not to ride it until you check that. If the valve isn't closing all the way, it doesn't take long to burn one, or the seat. It could be just the carbs though.
          • thewiz
            • Oct 2006
            • 1115
            • Wilksboro, NC
            #50
            Well, I did not re read this whole thread ...
            BUT .... a regular old backfire will blow the manifold vacuum cap off or apart. If it is constantly huffing out of that hole, there is a problem with a valve stuck open, burned or bent ... some way compression is leaking out of the combustion chamber.
            If it were me, I would run compression before I invested too much effort in the carbs just yet ... JMHO
            80G Mini-bagger
            Past XS11s
            • thewiz
              • Oct 2006
              • 1115
              • Wilksboro, NC
              #51
              I'm just too slow ...
              today, Tod. lol Guess I must be gettin' long in the tooth.
              80G Mini-bagger
              Past XS11s
              • Varnae
                • Aug 2008
                • 318
                • Noblesville, IN
                #52
                Unfortunately I don't have a compression gauge. I'm sure I could probably get my hands on one, but even if I did, I wouldn't know what to do with it. I do know that if I put my finger over that hole though, it repeatedly blows out instead of sucking in, thus leading me to believe that the valve isn't seating correctly.
                I'm sure it would still be a good idea to clean the carbs, as it was a "mechanic" that supposedly cleaned them before and well, with all that I've had to do to the bike after getting it back from him, I'll just say, it would be a good thing for me to give them a second cleaning.
                1980 MNS
                • thewiz
                  • Oct 2006
                  • 1115
                  • Wilksboro, NC
                  #53
                  You bet, it is a good idea to clean ...
                  your carbs thoroughly. Unfortunately, with a cylinder leaking compression badly, it's unlikely you'll notice too much of a difference. Kinda' like pissin' up a rope.
                  Get your hands on one, preferably the screw-in kind, warm up the engine, remove all the spark plugs, unplug the smaller plug on the TCI, then screw the guage into the hole in question and hit the starter button. Crank the engine for a few seconds noting the the highest reading on the guage then recording it on a piece of paper, hit the release button on the guage to zero it back out and repeat the process for the other cylinders, keeping track.
                  Do this, if you can, and then tell us what you recorded and observed.
                  Hate to say this, but it doesn't sound good and the comp test will help us to advise you correctly.
                  80G Mini-bagger
                  Past XS11s
                    • 8962
                    Also, throttle should be held wide open during the compression test, unless your carbs are already off the bike.
                    • petejw
                      • 2269
                      • sydney australia
                      #55
                      Glad to hear your getting it all sorted,
                      as good as a compression check is, it wont always
                      show incorrect valve adjustment.
                      I had 150psi right across the board, even tho 3 intake valves
                      had no clearances, made a huge difference when it was corrected,
                      well worth checking your valve clearances.
                      pete
                      new owner of
                      08 gen2 hayabusa
                      former owner
                      zrx carbs
                      18mm float height
                      145 main jets
                      38 pilots
