plugging the yics
  • #61
    Originally posted by yamahansolo View Post
    no i rode last night to work... got sprinkled on coming home!!!
    no i was just trying to figure out if the yics was "really " any good???
    also i know about the v boost system i still have the 85 shop manual i got the bike for a steal all the bits were in boxes and i had to put the whole thing back together. it took too long though!!!
    i just thought about trying to make a v boost type system for the xs since i have room to scoot the carbs up some. this would make the zrx carbs unneccisary and i could sell them...
    and i thought the flowtech or whatever it was called i forgot sounded like a good idea??? but only if it works... i wasn't trying to bust your kiwi's
    That's cool, I wasn't offended.
    I think the V-boost system is a cool idea, but it would be hard to do on an XS1100. It's MHO that the YICS system is one of those ideas that sounds great (marketing ) but doesn't work that well in reality.
    Larry
    82 XJ1100
    80 XS1100G (Project bike)
    64 Yamaha YA-6
    77 Suzuki TS-185
    • #62
      Yikes
      the letters looked kool
      XJ1100K
      Avon rubber
      MikesXS black coils
      Iridium plugs w/ 1k caps
      MikesXS front master
      Loud Horns (Stebel/Fiamm)
      Progressive fork springs
      CIBIE headlight reflector
      YICS Eliminator
      • #63
        Yes they do
        Larry
        82 XJ1100
        64 Yamaha YA-6
        77 Suzuki TS-185
        • #64
          Just wanted to let everyone know that the YICS Eliminator tool is now available on eBay. It is still available here at the XS11 web site as well.
          Thanks,
          Larry
          82 XJ1100
          64 Yamaha YA-6
          77 Suzuki TS-185
          • #65
            Not sure how I missed this thread
            I have eliminated my YICS, but in a slightly different way due to my engine being apart. This is defiantly a great way to do it for those that don't have the head off and don't want to. A big hurrah to getting rid of the bane of carb tuning.
            K. Johnson
            -1978 XS750SF - brought back from the dead with carb
            triple clean and boots
            -1982 XJ1100J - brought back from the dead by
            replacing motor after throwing #4 rod
            -1985 XJ750XN - shim job, oil change, ride. not bad for
            $500 including new rear tire.
            • #66
              ka-ching
              I ordered one through eBay . My handle is "mozeater"
              XJ1100K
              Avon rubber
              MikesXS black coils
              YICS Eliminator
              • #67
                Thank you, it is much appreciated.
                Larry
                82 XJ1100
                64 Yamaha YA-6
                77 Suzuki TS-185
                • #68
                  flo commander... that was it...
                  also the new vmax has the variable intake runners like the r1. at upper rpm's the top half of the velocity stacks come off and make them shorter...
                  79 xs11 standard
                  8mm msd wires
                  tkat fork brace...
                  Fox shocks...
                  mikes650 front fender
                  led's gallore...
                  renthal bars
                  gold valve emulators
                  vmax tensioner
                  Rifle fairing
                  • #69
                    The YICS ELIMINATOR WORKS GREAT!!
                    Hey Yahman,
                    When I installed the eliminator a few months ago the bike ran worse than without it. I thought that we had synched the carbs a few weeks earlier using the homemade yics tool. So, I took it out and waited for the next opportunity Bikerphil could come visit with his sychronizer.
                    Well, today was the day....
                    We installed the Eliminator and fired it up, couldn't believe how far off the carbs were. I must have done something wrong building the homemade yics tool!! Anyway the bike ran great after Phil synched the carbs!! It even corrected a bit of a stutter it had between 1,500 and 2,100 RPMs. The XJ has become my daily rider so I'll keep you posted.
                    BTW - How long have you ridden yours with Eliminator in and how are the O-rings hoding up.
                    Thanks for a great solution to a PITA problem.
                    1980G Standard, Restored
                    Kerker 4 - 1
                    850 Rear End Mod
                    Automatic CCT
                    1980GH Special, Restored
                    '82 XJ1100 (Sold)
                    • #70
                      Originally posted by Cobia View Post
                      Hey Yahman, How long have you ridden yours with Eliminator in and how are the O-rings hooding up.
                      Thank you Cobia for the great testimony.
                      I've put a little over 300 miles on my XJ with the YICS Eliminator installed. It runs great and I see no need to remove it.
                      The Viton O-rings meet "American Society for Testing and Materials" (ASTM), and "Society of Automotive Engineers" (SAE) Specifications. They should last for at least 40,000 miles if you just install it and do not remove it. The only real wear and tear that happens to the O-rings is when the YICS Eliminator is removed from the engine.
                      If anyone else would like a YICS Eliminator tool they are available on eBay, just do a search using "YICS Eliminator" and you should find it. Or you can click on the link below for more info.
                      Thanks,
                      Larry
                      82 XJ1100
                      64 Yamaha YA-6
                      77 Suzuki TS-185
                      • #71
                        Tool Installed
                        Today I finally got to install "The Eliminator" . I had to clean the passage and had a tense moment when I got the cleaning apparatus ( wire and cloth) stuck but all went well . I was surprised at synch time that my levels were close which leads me to imagine that it may have been plugged with crap . Never-the-less , my bike runs great and sounds great and I'm definately leaving it in .
                        Hi I'm Axel and I'm a ex-YICSer
                        XJ1100K
                        Avon rubber
                        MikesXS black coils
                        YICS Eliminator
                        • #72
                          OK,SO do a search!!!! There is a memeber here who MAKES a "block off" for the YICS. As I have only OLDER bikes, I don't remember everything about it.
                          • #73
                            I still have not installed mine yet but it will get done in the next few weeks cant wait to get my bike back
                            1980 XS650G Special-Two
                            1993 Honda ST1100
                            • #74
                              Dude
                              Ray - what are you on about ?
                              lol
                              XJ1100K
                              Avon rubber
                              MikesXS black coils
                              YICS Eliminator
                              • #75
                                More ?
                                Hey Larry . I see your ebay listing has ended . Do you have more Eliminators ? I have a fellow interested in one
                                XJ1100K
                                Avon rubber
                                MikesXS black coils
                                YICS Eliminator
