And It Begins ... again :-)
  • planedick
    • Mar 2005
    • 2068
    • Yorba Linda, California
    #61
    Oil pressure
    depends on the spring and check ball at the pump. The '79 I had would pump 50 lbs when cold, the '78 does 40 and the engine from the '79 special only does 30. It's the pressure required to push the ball against the spring and bypass back to the sump. I can be raised with washers under the spring. Of sourse it takes very little pressure to float a bearing.
    Drilled airbox
    Tkat fork brace
    Hardly mufflers
    late model carbs
    Newer style fuses
    Oil pressure guage
    Custom security system
    Stainless braid brake lines
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #62
      link
      is there a link with write up on that bolt removal and gauge install?
      MDRNF
      79F.....Not Stock
      • 79XS11F
        • 3563
        • Ottawa, Ont. Canada
        #63
        A sealed unit
        So other then the oil filter housing and head oil supply pipe, which on this engine goes to an oil cooler, this engine is complete and ready to pop into the frame which will be started later today or on the weekend. More photos of this engine. The last 2 are from above the way the engine would be seen in the bike.
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #64
          BLING
          Hey Rob, that's just about narcissistic........I really am diggin' that oil gauge, looks factory...chop
          MDRNF
          79F.....Not Stock
          • egsols
            • Jan 2006
            • 1090
            • Barrie, Ontario, Canada
            #65
            Rob,
            That's slick!!!!
            I like the filter for the case vent!
            The oil gauge looks awesome, like chop said...factory!
            Couple questions though...
            I'm thinking that's a 78/79 motor but the kirkstart hole is covered like on a 80/81. Is it a 80/81 motor or a 78/79 motor with an 80 cover or did you remove the kirkstart and make your own cover?
            What are using for filters on the carb vent hoses?
            How come you are running vac lines between 1 and 2 and 3 and 4?
            Hope my questions don't come across as being dopey, I'm just curious cause I ran a line from 1 to 2 when I didn't have an extra cap after losing the octi. I was concerned though that linking them could cause me problems. I'm also planning on going to pods and have been thinking of ways to filter the vent hoses while still allowing them enough flow to breath properly.
            Ernie
            • 79XS11F
              • 3563
              #66
              Originally posted by egsols
              Rob,
              That's slick!!!!
              Vac lines between carb boots is to keep out bugs until the engine is mounted and the fuel tank hooked up.
              This is a 1978 engine and I have removed the kick starter parts both inside and outside the cases. The "plug" that covers the hole where the kicker shaft used to be is still available from Yamaha.
              Carb vent hoses will be routed to a filter up under the fuel tank. I will use a fuel filter from CTC that fits for that job. They don't really need to breath so to speak. They just need to be open to the outside. That being said I was thinking of connecting them to the outside pod filters because there must be some negative air pressure in the air box where they usually hook up. I am however thinking that too much negative air pressure like in the pods might draw fuel up the lines or cause other unknown issues.
              You should be able to find new bullet caps at any auto supply shop. They are just vac nipple covers. S**t ... all my vac lines are from CTC (windshield washer hose) and I have been told it will take the heat so long as it is not in contact with hot parts.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • egsols
                • Jan 2006
                • 1090
                #67
                Thanks for the info Rob,
                I'm still confused on the vents though. I was thinking of a fuel filter too but don't they also need to let a little air in to balance out the level when the fuel drops?
                Ernie
                • 79XS11F
                  • 3563
                  #68
                  They simply need to be unplugged and open the the outside air. Otherwise when fuel in the bowls drops a vacuum would be created in the vents and incoming fuel would be draw up those hoses like a straw. The only real reason they normally vent into the air box is to make the bike run cleaner and meet EPA standards that don't allow raw fuel to be vented into the air. EPA wants that fuel fumes recycled into the intake system.
                  A fuel filter will work just fine to keep out dirt and dust.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • blue giant
                    • Aug 2007
                    • 880
                    • Ontario, Canada
                    #69
                    That's awesome Rob!
                    I know a bike that that engine would fit in, it's just waiting for an engine as we speak!
                    Paul
                    1983 XJ1100 Maxim
                    1979 XS1100 Standard
                    1980 XS1100 Special
                    • 79XS11F
                      • 3563
                      #70
                      Re: link
                      I'm not sure chop ... This units install was easy due to the gauge being made for the 1100. I compared the bolt that came with the unit and other then the extension to receive the gauge it is the same.
                      Rob
                      1978 XS500E
                      1981 Suzuki GS1100
                      • 79XS11F
                        • 3563
                        #71
                        Originally posted by blue giant
                        That's awesome Rob!
                        I wish I had a bike ready to receive it myself. That's the next step. Building the bike itself.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #72
                          gauge bolt
                          I just want the gauge to be positioned just as you have yours so I can see it while I'm sitting on the bike... I want the adapter in SS also....
                          MDRNF
                          79F.....Not Stock
                          • 79XS11F
                            • 3563
                            #73
                            Ya ... that looks like it will easy to check at that location.
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                              #74
                              You do realize, I suspect, that if you throw in a T on each side, and connect the Ts to each other, that you will in effect create a YICS system on your pre-YICS engine?
                              • petejw
                                • 2269
                                • sydney australia
                                #75
                                hey rob,
                                that engine looks unreal,
                                im wanting to do the same thing eventally,
                                im trying for a mirror finish.
                                can u do a write up with what u used as in buffing
                                wheels, steel/brass wheels, polish etc
                                how did u get into all those little crevices
                                to get it looking like that, :-)
                                how did u do ur fins?
                                thanx
                                pete
                                pete
                                new owner of
                                08 gen2 hayabusa
                                former owner
                                1981 xs1100 RH (aus) (5N5)
                                zrx carbs
                                18mm float height
                                145 main jets
                                38 pilots
