And It Begins ... again :-)
  • 79XS11F
    • 3563
    • Ottawa, Ont. Canada
    Your eyes are not playing tricks on you. It is an extension and my oil pressure gauge will go at the end of it.
    Rob
    KEEP THE RUBBER SIDE DOWN
    1978 XS1100E Modified
    1978 XS500E
    1979 XS1100F Restored
    1981 Suzuki GS1100
    1983 Suzuki GS750S Katana
    1983 Honda CB900 Custom
    • egsols
      • Jan 2006
      • 1090
      • Barrie, Ontario, Canada
      Did you fab it yourself?
      Ernie
      • 79XS11F
        • 3563
        Confused now ... are you referring to the casting lug with the hole in it or the raised pipe like bump that goes off to the left with the bolt at the end? The casting lug with the hole in it is where the head oil supply pipe goes and the other is on all XS1100 engines that I have seen. It is a supply line for the bearing at that side and is capped with that bolt. That bolt will be replaced with an oil pressure gauge.
        Rob
        1978 XS500E
        1981 Suzuki GS1100
        • 79XS11F
          • 3563
          Stripping the top end
          So now the top end gets stripped for buffing .. WOW the aircraft coating remover works like nothing else I have ever used.
          Rob
          1978 XS500E
          1981 Suzuki GS1100
          • egsols
            • Jan 2006
            • 1090
            confused
            I thought it was on all of them but with your engine out and clean it stood out. I am correct in thinking that a gauge can go in the end of where I have marked it?
            BTW, did you ever find cheaper insurance?
            Ernie
            • 79XS11F
              • 3563
              confused
              YES .. The gauge will replace that cap bolt.
              The raised area in the case casting was like that. It is like that on all 3 of my xs11 engines that I have here.
              I have not restarted the search for insurance for the 750 Kat yet because the bike is not running well enough yet to become my planned every day ride. I still need a safety which I hope to get done at the end of this week.
              Rob
              1978 XS500E
              1981 Suzuki GS1100
              • randy
                • Dec 2003
                • 4521
                Beware when installing a pressure gauge at the tranny banjo. Take a good look at the banjo bolt, the oil holes are not standard spacing. Unless you bought a gauge setup specifically for the XS11, you may block the oil passage when installing the gauge.
                I installed a remote pressure gauge with a S/S line at this union, but had to fabricate a banjo bolt to fit. IIRC, someone else here did the same thing, just don't remember who!
                • 79XS11F
                  • 3563
                  Thanks for the heads up Randy .. The gauge i bought is for the XS1100 But i will check this out carefully during the install. Perhaps I will install the gauge with the bearing support removed (for buffing) and confirm oil flow at that location.
                  Rob
                  1978 XS500E
                  1981 Suzuki GS1100
                  • DJinNH
                    • Mar 2008
                    • 854
                    • New Hampshire
                    Originally posted by blue giant
                    Looking Good Rob,
                    When do you want me to drop off my engine?
                    Ya, really.... Now he's got me looking at my engine in disgust even after all the cleaning I've been trying to do.
                    Man, does that engine look sharp!
                    Don
                    currently own;
                    1980 Yamaha XS1100 SG
                    2009 Yamaha Star Raider
                    • 79XS11F
                      • 3563
                      Happy enough with the results
                      Now the top end is complete and so is the engine. I just finished spraying her down with 3 cans of brake cleaner. That's required to clean the pores of the buffed metal. I will not bother getting out the moto tool to get right to the back of the fins. The valve cover and engine side covers will be done separately. This engine is now ready to be reassembled for the bike :-)
                      1978 XS500E
                      1981 Suzuki GS1100
                      • 79XS11F
                        • 3563
                        Don
                        Hey Don ... Keep in mind that when you clean your engine you are cleaning aged PAINT. This engine has the paint removed and the alloy buffed to a high brushed shine. That's the difference.
                        Rob
                        1978 XS500E
                        1981 Suzuki GS1100
                        • egsols
                          • Jan 2006
                          • 1090
                          Rob, where did you buy it?
                          Randy, I remember reading that too! Planedick made up a special adapter. http://www.xs11.com/forum/showthread...5&pagenumber=1
                          Ernie
                          • 79XS11F
                            • 3563
                            I got it on e-Bay ... Don't see them too often but I'm sure you could get one at an auto supply shop and install it as Randy did.
                            Rob
                            1978 XS500E
                            1981 Suzuki GS1100
                            • egsols
                              • Jan 2006
                              • 1090
                              Posted by egsols at 9:54 "Rob, where did you buy it?"
                              Posted by 79XS11F at 9:57 "I got it on Ebay...."
                              Could you reply any quicker next time, (I hate waiting over two minutes)???????
                              Thanks
                              Ernie
                              • 79XS11F
                                • 3563
                                Thanks
                                I just happen to be sitting here :-)
                                Rob
                                1978 XS500E
                                1981 Suzuki GS1100
