oil cooler results #2
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #46
    o.k.
    will I be able to put my lockhart cooler on with it? and while your here. How does the oil routing go thru the cooler adapter plate? I don't want to assume anything I haven't seen. I think TC's adapter can be modified to route cooler lines....
    MDRNF
    79F.....Not Stock
    • Pat Kelly
      • 3046
      • Golden Valley, AZ
      #47
      My Lockhart oil cooler plate does not have the bypass valve/spring. The OEM Yamaha one I had did have the bypass.
      Pat Kelly
      <p-lkelly@sbcglobal.net>
      1978 XS1100E (The Force)
      1980 XS1100LG (The Dark Side)
      1999 Suburban (The Ship)
      1994 Dodge Spirit (Son #1)
      1968 F100 (Valentine)
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #48
        flow direction
        from the xs11 engine, does the oil flow into the threaded part of the SOFA or vice versa?
        MDRNF
        79F.....Not Stock
        • planedick
          • Mar 2005
          • 2068
          • Yorba Linda, California
          #49
          OR...
          Visa versa, first into the outside of the filter then through it then to the center to the oil passages.
          Drilled airbox
          Tkat fork brace
          Hardly mufflers
          late model carbs
          Newer style fuses
          Oil pressure guage
          Custom security system
          Stainless braid brake lines
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #50
            I'd but that
            Hey T.C. I'd pay $75 for one of these.....I'm sure others would too...The blue ring is the O-Ring. The red lines are solid material(no holes) the rest is self explanatory
            MDRNF
            79F.....Not Stock
            • xschop
              • Feb 2006
              • 1794
              • oklahoma city
              #51
              total thickness
              2" (possible 1.5") total thickness with 1/4" in/out ports.....
              MDRNF
              79F.....Not Stock
              • red bandit
                • 951
                • central michigan
                #52
                chop, I don't think you need all of that ID dished out . Can't remember for sure??? Put your 2 fitting holes that could be side by side laterally (which will make the adapter thinner) and instead of the dished out part, just drill a hole connecting the ports, one toward the engine, 1 towards the filter. Can't remember what the inside of housing looks like but I think that will work. Tryed to load pic...not puter savy.
                79 SF parts bike.
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #53
                  design
                  this design will cool the oil before the filter. I was going to ask but if the early reply was true then the original adapter sends the oil from the crankcase to the cooler first as well.... The Adapter above can be made of good structure from 1.75" thickness....chop
                  MDRNF
                  79F.....Not Stock
                  • 81xsproject
                    • 3185
                    • Fortuna, CA
                    #54
                    Good job Chop. Effectice and simple. Just trying to fully understand the enire pocess; comes in from above in the upper large chamber, goes to cooler out the hole, comes back into the lower large chamber through the lower hole, enters the outer holes in the filter, gets filtered as it moves form outside into the center of the filter, then goes back up the green tube to the motor?
                    '81 XS1100 SH
                    Sep. 12th 2015
                    RIP
                    • xschop
                      • Feb 2006
                      • 1794
                      • oklahoma city
                      #55
                      Anyone else?
                      according to Plane, that's the flow route....
                      MDRNF
                      79F.....Not Stock
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #56
                        thanks bandit
                        the total thickness with this design can go 1.25" and still be structurally sound.....
                        MDRNF
                        79F.....Not Stock
                        • HobbyMan
                          MeatHead Idiot "GURU"
                          • Jul 2006
                          • 1801
                          • Colleyville, TX
                          #57
                          deleted post: missed something sorry
                          Acta Non Verba
                            • 7714
                            xschop,
                            If you had the top and bottom "chambers" at an angle, you can reduce the thickness of the adapter to .75". I would put the inlet and outlet at least 90 degrees apart. This will allow the internal room for 3/8" fittings, and still keep the over all height down.
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              #59
                              rough draft
                              I am fine tuning the drawing, but you would need at least (or I would want) 1/2 thickness seperating the two chambers for the bolt to thread into/or locknut from below(TC already found this out)...and yes the in/out ports I would stagger for nipple fittings... How tall is the FRAM PH3950? thats the one I thought went on my Honda Civic, wide but short....ideal
                              MDRNF
                              79F.....Not Stock
                                • 7714
                                Remember, the chambers DO NOT need to be flat, just flat at the center mount. It would take a little more machine work, but I think it could be done easily. I just don't have anything here at work I can draw and scan, so I'll have to wait until later to try and send you a PM with the drawing.
