Who Wants A Bolt-on Chaindrive And Fat Tire?
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #136
    wheel hub
    O.K. I know that the ZRX12 stock wheel is 180 and ZRX11 is 170 from factory, but not sure if the rear rims are different. I will measure tonight and email you. I just sent out your ' Busa brake line USPS. Does it look like you got every piece/spacers from the rear axle? I didn't even recognize the small washer that goes on the axle nut until I disassembled for that pic....I really am starting to get tired of this SamSung 5 mpxl camera
    MDRNF
    79F.....Not Stock
    • scappod
      • Mar 2005
      • 233
      • Bremerton Washington
      #137
      rear wheel
      Sounds good to me, it apears that I have everything I was just wondering because I think I have the wrong axle I cant get the thing to snug down... anyway I was just wondering
      Ego Sum Meus Frater Custodis...
      • xschop
        • Feb 2006
        • 1794
        • oklahoma city
        #138
        ZRX11 axle measurements
        Hub (including both installed bearings)= 6 1/8"
        Axle bolt= 12 3/4 total length end to threaded end
        Axle nut= 1 1/8 total length end to end
        MDRNF
        79F.....Not Stock
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #139
          Monoshock
          Finally got a reply about this swingarm's measurements....Would be another candidate for the XS11 chaindrive conversion with monoshock....It even has the mount for the shock already there. And I would also bet the battery box can stay factory.....Chop
          EBAY #270243439095
          MDRNF
          79F.....Not Stock
          • xschop
            • Feb 2006
            • 1794
            • oklahoma city
            #140
            battery box problem
            On the Triumph St, I had to relocate Battery Box because of the shock angle position....Here, The Ducati Monoshock is straight up-and-down....
            Entra su Libero.it: Mail e Email PEC, Login, le Ultime Notizie con aggiornamento quotidiano, Video, Motore di Ricerca e tanto altro
            MDRNF
            79F.....Not Stock
            • Mathh
              • Nov 2006
              • 698
              • Beek, Netherlands
              #141
              Re: battery box problem
              http://digilander.libero.it/avanini/...0FE%20sm_a.jpg
              Hi xschop,
              The ducati monoshock is push/pull rod activated, The swingarms moves the rod up or down and activates the monoshock via a link mounted in the frame below the rear of the tank.
              When you look closely you see the rod that goed from behind the carbon heelplate to the upper part of the frame triangle. There it activates the link. The bolt that holds it can be seen left of the seat lock.
              MV Agusta Brutale 910R '06.
              Yamaha MT-09 Tracer '15 grey.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #142
                better shock
                Yes, I believe that this is a better monoshock design because there is only 1 frame mount point where you explained, the other 2 are both on the swingarm itself (link and shock locations)....Even better for the swap because you just have to weld one location to the XS11 right behind the battery box....chop
                MDRNF
                79F.....Not Stock
                • 79XS11F
                  • Jul 2006
                  • 3563
                  • Ottawa, Ont. Canada
                  #143
                  Found one
                  Finally I have found and bough a swing arm off a ZRX1100 Kaw.
                  My own project bike should be easier to complete now.
                  Rob
                  KEEP THE RUBBER SIDE DOWN
                  1978 XS1100E Modified
                  1978 XS500E
                  1979 XS1100F Restored
                  1981 Suzuki GS1100
                  1983 Suzuki GS750S Katana
                  1983 Honda CB900 Custom
                  • xschop
                    • Feb 2006
                    • 1794
                    • oklahoma city
                    #144
                    ZRX swingarm
                    I made an extra set of adapters/swingarm pivot bolt.... I will have to get to the shop this weekend and spin out a right side swingarm pivot bolt....PM'd you....chop
                    MDRNF
                    79F.....Not Stock
                    • chrisso
                      • Jun 2008
                      • 182
                      • Sydney Australia
                      #145
                      just found this thread--I would be interestd in the Chain conversion in the future.. what sort of weight are talking about(for the whole setup..... im trying to work out approx costs fr shipping to Oz). cheers, Chrisso
                      80 XS11 Standard Australia
                      • xschop
                        • Feb 2006
                        • 1794
                        • oklahoma city
                        #146
                        weight
                        the parts you need, (1-piece chaindrive housing)......
                        and ZRX1100 swingarm bolt and spacers weigh less than 14 lbs...
                        MDRNF
                        79F.....Not Stock
                        • 79XS11F
                          • Jul 2006
                          • 3563
                          #147
                          Hey chop .. I am guessing that I will be best off to acquire a rear axle for the ZRX1100 swing arm for this set up that uses the 650 rear wheel? I guess I also will have to look into how to set up the rear brake and space it proper as well.
                          Rob
                          1978 XS500E
                          1981 Suzuki GS1100
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #148
                            Yes
                            Get the zrx1100 rear axle. I think Scappod got the Zrx1200 axle from ebay and it was longer, make sure it's the 1100 for your swingarm....The Zrx1100 axle is 20mm Dia. Same as XS1100, and I think same as xs650.....your bike will look cool....Since you are grafting the 650 rim to the zrx swingarm, you will have to make sure of your rim centerline first, then make the axle/rim spacers.....
                            MDRNF
                            79F.....Not Stock
                            • xschop
                              • Feb 2006
                              • 1794
                              • oklahoma city
                              #149
                              rear brake line
                              A rear brake line of 27" is perfect for your swap. I sent one to Scap from a Front Busa Line and he said it fit right on...chop
                              MDRNF
                              79F.....Not Stock
                              • 79XS11F
                                • Jul 2006
                                • 3563
                                #150
                                If axle DIA is the same I will wait until the swing arm arrives and check it out. The 650 rear wheel is the same as the xs1100 except with a sprocket. I may have to Fidel around with the rear brake if I want to make use of the existing mount bracket. The 650 rear wheel may look small in that swing arm ... we'll see :-)
                                Rob
                                1978 XS500E
                                1981 Suzuki GS1100
