Bolts No problem
I can get all the bolts.the longest stock M/D bolt is 160mm. I can get bolts up to 225mm long. One thing Denny, if you want to go wider than 180, I believe you might have to make you spline extention longer and move your right side frame pivot points out as well. I figure 35mm, maybe 40mm spacer will only require moving the left side frame points out. the stock tire location looks like it could go to the right 35mm without hitting the right side swing-arm. For 50Gary, I wouldn't want to cut anywhere in the RED are, and only in the Blue, because of the bearing circlip....what you guys think?
