Thanks! That's what I was trying to say in the last post. As long as the voltage is higher than what a single cell should be, the "Batt" warning will be off to my logic.
Even though it functions when all is well connected to the positive battery terminal, a single cell would never feed 12 volts to the cluster. As has been said, if something goes wonky, not sure what would happen or if I would like what happens given it's a perfectly functioning 44-year-old cluster.
Back to the question, running it off of the battery with a fuse in line and a resistor, what size fuse would you all go with? A 5 amp, 10 amp etc?
