1982 Seca XJ750, ZRX1200 has company now.
    • 3262
    I think the logic is a bit different than the sensor is at 12V vs the voltage on one cell. I honestly don't remember the whole story. The XJ forums can serve as a refresher. I think the sensor itself was around 1k ohm when the electrolyte was present, and the cluster reads the voltage more than the current.....or something like that.
    Thanks! That's what I was trying to say in the last post. As long as the voltage is higher than what a single cell should be, the "Batt" warning will be off to my logic.
    Even though it functions when all is well connected to the positive battery terminal, a single cell would never feed 12 volts to the cluster. As has been said, if something goes wonky, not sure what would happen or if I would like what happens given it's a perfectly functioning 44-year-old cluster.
    Back to the question, running it off of the battery with a fuse in line and a resistor, what size fuse would you all go with? A 5 amp, 10 amp etc?
    ZRX1200
    Seca 750
      • 2096
      I would choose the smallest available fuse, like 1A or less.
      This circuit will draw negligible current.
        • 3262
        Thank you for that input!
        Found another inconsistency with the carburetors today. Number four is from an early XJ650, needle was also from the XJ650, wasn't paid attention to by the dealer who rebuilt the carbs for my uncle, nor by me when unracking for cleaning last fall... XJ650 needles are much richer (#Y-10) than the XJ750 needles (#Y-13). Changed it out for the proper needle today from a spare carb.
        A "my bad"... In going down "one size" on the pilot jets, I inadvertently went down two sizes. Hitachi's go by one number vs most others go by 2 numbers per size. Makes sense now why 38's are too small and 4+ turns out still isn't enough fuel at idle, even at 7200' elevation. Putting stock pilots back in, #40. Slowly sneaking up on getting this thing dialed in from all angles.
        ZRX1200
        Seca 750
          • 3262
          40 pilots back in, screws 2.5 turns out. Starts with enrichener as it did with the 38 Pilots at 4-4.5 turns. A change for the better as I have adjustments both ways now.
          Been dealing with an intermittent #2 cylinder. Swapped two and three plug wires, as there's a "wasted spark". For those that aren't familiar with wasted spark, this means both 2 and 3 fire from the same coil at the same time but only one of them is on the compression stroke so the other is wasted in space so to speak. New plugs are in, new eBay coil with new plug wires on two and three produces the same result.
          I've discovered it's idle where #2 pipe stays cold. Hold the throttle at 1500 - 2000 RPM or higher, number two heats up. Either sync w/o YICS block off has a throttle plate covering the number two idle hole in the carburetor throat or number two pilot circuit needs another thorough cleaning.
          What does the collective say? Been talking with JeffH, he agrees those are two things to check as I've been narrowing it down talking with him over the last week.
          ZRX1200
          Seca 750
            • 1947
            Just food for thought I had a brand new pilot jet that was just bad. I fought with that until I finally just replaced it and then all was good. Question for you and I haven't spent the time to re read the whole thread but did you have the same issue with the smaller jets? If you are sure the jets are good then I have to agree with you it's time for another clean. I know you are aware, but for the collective a good soak in a gallon can of Berryman's might do the trick.
              • 3262
              Thanks for posting up. You are correct. Went down to smaller pilots, brand new from Jets R Us yet number two was not coming online until the throttle is open to 1500-2000 rpm or more. Stock pilots in there are clean, did another soak in Berryman's can of cleaner, rinsed them with gasoline, blew them out with compressed air, holes are as wide open as they can be for pilot jets.
              Did an impromptu cleaning on all 4 pilot circuits. Removed screw, spring, washer and o-ring. Sprayed cleaner in the hole while the engine was running. Then four or five seconds later chased it with gasoline from the auxiliary fuel source tube straight through the pilot hole for 5 or so seconds. I could watch the gasoline burble in the pilot screw hole itself. Something's functioning in the circuit. And it was the same response on all for pilot circuits. Number two was not weak or any noticeable difference. I've compared pilot screws, 1,2 3 are identical (#4 is the course thread for the XJ650 carb body, that is adjusted fine on number four) and are clean, smooth and no damage to the tips. Hitachi carbs, pilot screws are on top and easily accessible with the tank off and remote fuel source.
              As a thought, I could pull a pilot screw from one of the other spare XJ750 carb bodies and give it a try. In any case, getting the carbs on and off is not a problem to clean that pilot circuit specifically on the bench.
              ZRX1200
              Seca 750
