1982 Seca XJ750, ZRX1200 has company now.
    • 3283
    Shinko 230's arrived. Goal is new float needles tomorrow, spin around the block. If all goes well with carbs sealing, wheels off and to local shop next week to get them mounted. Tire mounting is the only thing I don't do, want to give some business to my local guy. IMO, good to have a relationship with at least one motorcycle repair shop. In case you need to borrow a tool such as an impact driver for carb rack screws... Have my own now, didn't when I needed one last fall working on a first generation Vmax carb rack.
    ZRX1200
    Seca 750
      • 3283
      It's been a minute since I posted on the Seca 750. It has been holed up for the "winter" that we never really had here in Colorado. The ZRX 1200 has gotten all riding which is a little over 2,000 miles since September given how mild the weather has been.
      Yesterday I rehabbed the stock float needles by polishing the brass bodies and using 3M label and adhesive remover on a soft cloth to clean the rubber needle tips. Spray a small amount on the cloth, spin the needle tip in the cloth with a relatively light pressure. Amazing the light layer of decomposed rubber for lack of a better term that each tip had. However the tips are all straight and true with no ring where they rest on the seat. They are decently pliable when compared to newer needle tips now that they are all cleaned up.
      I had used the 3 mm float bowl fuel level that's in the factory service manual when setting the floats previously and the closer I got to 3 mm, the more the carbs would dump fuel with the aftermarket repair kit needles. Went back to a "set it and forget it" mindset with the rehabbed stock float needles and put them at 17.5mm +/- .5mm. Did a trial run on the bench and the carbs sealed up with no issues.
      Got them back on the bike, started right up and I'm really pleased.
      Front brakes as I posted last fall are completely rebuilt and that master cylinder behind the light was the biggest pain in the butt.
      Today is going to be spent getting the wires back into the headlight housing along with the horns that mount inside of there as well. Had to remove the headlight housing and disconnect a lot of wires to get the clearance to get that master cylinder out.
      As well, I noticed yesterday number two cylinder would cut in and out, traced it easily and quickly to a plug wire connecting to the boot on the number two cylinder. Going to trim all the wires back to expose fresh wire which probably should be done anyway even if they were working fine given the age of the bike.
      Anyway, it's in the home stretch now that the carbs seem to be good.
      ZRX1200
      Seca 750
        • 3283
        Instead of making the above post from earlier this morning longer, I would like some thoughts:
        This morning, 40°- 45° temperature in the garage here at 7,200' in Palmer Lake. Bike started without any enrichener, almost settled into a steady idle and would take gentle throttle without a problem to steady the idle.
        I'm running one size smaller pilot jets than stock and have the screws at two turns out from seated on carbs one through three and one and a half turns on number four because it has a body from an early XJ650 apparently, those had a coarse thread pilot screw that moves further with every turn. Mains are 118 (stock 120), pilots 38 (40 stock), pilot air jets are stock at 225 and 80. Hitachi carbs used some interesting design, but seem to have had a good run of success back in the day.
        Question: Screws are in about as far as practical, go down another size on pilots? It shouldn't start that easily at that temperature without the enrichener IMO. For information, with the enrichener off, the plungers are fully seated so there's no unintended enrichening taking place.
        ZRX1200
        Seca 750
          • 3283
          Put the first mile on it since it was last plated in Illinois in 2007. Front brakes are marginal with respect to feel because of the remote master cylinder behind the headlight that's activated from the lever by a cable, front brake power was average at best. Rear drum brake has good feel and good modulation. Shifted fine, pulled cleanly.
          Put fuel screws at 3 turns out after playing with them a bit before the maiden voyage. Idle would stay high, sometimes it would drop back down but still higher than spec. I'll play with the idle adjustment, a synchronization will help as well. Time for a YICS tool of one type or another.
          Now it can sit proudly next to it's ZRX 1200 stable mate in the garage.
          ZRX1200
          Seca 750
            • 1985
            Howard, If you think the pilot screws are turned in as far as you want then I don't see any other alternative but to go down a size on the jets. I agree with you that it should not be idling on cold starts and for sure not with the temps you described. Running way rich.
              • 3283
              Thanks for responding. It's perplexing because I'm already down one size on the pilots from stock. Past experience at 7200' elevation says that usually does the trick. The Hitachi carburetors have pilot air jets, figured it would be best to lean out the pilot circuit with smaller fuel jets. Pilot air jets are opposite effect. The larger the number, the leaner the mixture. In any case I'll play with it some more and keep you all posted.
              ZRX1200
              Seca 750
                • 289
                Sounds like a nice little ripper getting some love,,,hope the seca keeps on going strong. If I get back from Pa end of June, hope to get out to Colorado for the annual Bonz XS rally, get together and I can bring the gauges and yics tool out..if it can wait that long..or if you are coming out to the NE rally I can bring them there,,,,,..still bummed about our fellow member Joe and Scott,,,,so, keep on restoring,,,seeya, Mike in S.Diego and Pa
                  • 3283
                  Can you share any more about Scott/3Phase? Bob XJOK2PLAY had told me he heard it when he alerted me to Joe's daughter's Facebook about Joe's passing.
                  I'll synchronize them the standard way, it'll get it close like everybody says it will. The YICS tool would be nice if you are going to make it out. We can check it in Westcliffe. If I pick one up in the meantime I'll let you know.
                  ZRX1200
                  Seca 750
                    • 3283
                    I've been breaking my number one rule of synchronizing the carbs right away as soon as the engine will run after major carb cleaning/work. Pulled my head out of my fanny and did that today. I attribute my recent posts and agony, lol, to not doing that.
                    As you know I don't have a block off tool. However I got them matched up nicely and it has made a difference. A blip of the throttle still returns a bit slower to idle than I want/than it should however it doesn't hang for a couple seconds anymore and comes down much more quickly, smoothly and consistently
                    To refresh, I went one size smaller than stock on the pilot jets. I am at three and a half turns out on the pilot screws. As a general rule I don't want to go past four turns otherwise they're not really making any difference because the idle circuit is running pretty much wide open at that point from what I understand. Going back to stock pilots may be a quick swap to see how it does.
                    It'll be very chilly in the garage in the morning, a good test to see if it still starts without enrichener or if it will need some. Hopefully I need to put in a good lever full of it, lol.
                    On another note, the Seca 750 had a very advanced monitoring system for 1982. The one bugaboo in this day and age is the battery fluid level/charge indicator. It's a sensor that would screw into one of the six cell cap holes. These days they are plugs and not screw in caps and the sensors are scarce as hens teeth or batteries are AGM and sealed. I put in an AGM battery. Found a work around. Cut the sensor wire, attach it to a any 12 volt source and it keeps the dash light from coming on. I hooked it up to the positive terminal on the battery and it keeps the "Batt" warning LCD segment from coming on the display.
                    ZRX1200
                    Seca 750
                      • 3283
                      Well, I out-thunk myself on the pilot jets at elevation. In a nutshell, after the carburetor sync last weekend, started the bike this afternoon when I got home from work. For grins opened the pilot screws from 3.5 to 4.0. Steadied things out more on the idle and got rid of the remaining lean return to idle hang when blipping the throttle.
                      With that, 4.0 turns is further out then they should be. 3.5 turns is the max in my book if the pilot jet is the correct size, going back to stock pilots.
                      ZRX1200
                      Seca 750
                      • LenB
                        • Nov 2020
                        • 160
                        • Winnipeg, Manitoba, Canada
                        #56
                        Just a word of caution regarding the battery electrolyte warning bypass. Did that on some other projects and picked up some fused power off the fuse block. Just in case something goes wonky it won't fry your sensitive electronics.
                        1980 XS1100G (one owner-me)
                        1984 Honda VF750S V45
                        Owned - 1976 XS750D
                        Owned - 1972 Honda CB750
                        Owned - (unknown year) XS650
                          • 3283
                          Thanks for that. It's an easy thing to pull that wire up and do that.
                          ZRX1200
                          Seca 750
                            • 2136
                            Wouldn't hurt to put a 1k or 2k resistor in the circuit. That's what many XJ owners do.
                              • 3283
                              I'm reading what you're saying. As it's 12 volts coming off the battery, it's more current than a single cell would be showing to the sensor, the resistor knocks that back so it's not feeding 12 volts to the instrument cluster? The sensor only needs minimum voltage from one cell, and 12 volts is higher than the minimum so the gauge cluster reads the battery is good.
                              Thinking on this, an inline fuse along with the resistor would be the way to go. Does a 10 amp inline fuse sound good or could/should a smaller one do the job? I'd rather isolate it coming off the battery versus vs fuse it off the fuse block.
                              ZRX1200
                              Seca 750
                                • 2136
                                I think the logic is a bit different than the sensor is at 12V vs the voltage on one cell. I honestly don't remember the whole story. The XJ forums can serve as a refresher. I think the sensor itself was around 1k ohm when the electrolyte was present, and the cluster reads the voltage more than the current.....or something like that.
