Well I must have must up in my arithmetic cause according to my calculation my c/l to ineer edge rear sprocket is 4.4375" or 112.7mm. Thast is almost what you said yours was Pggg. and according to my measurements and calculations I needed to move my front sprocket out on the middle gear shaft 12.7 mm. That would almost be 16mm to the opposite direction of yours. I screwed something up somewhere. Pggg Do you know what the distance is from c/l to the inner edge of your front sprocket is? According to my measurements(not 100% accurate mind you) it should be about 97mm? Sorry bout all the questions , but do you know the distance between your outer edge of your tire and the inner edge of the rear sprocket. I think I may have to switch to a 520 chain cause right now according to my calculations I only have 12 mm or so between my tire and the inner edge of my sprocket. If the 530 chain is that wide I am probably gonna rub? I went to this website http://www.gizmology.net/sprockets.htm and it says the rollers on a 530 are 3/8ths wide which is 9.525mm. That would put the plates connecting the rollers at 3.868mm wide. That is a freakin heavy duty chain. Now that I did the math I should be OK. That would give me almost 5 mm between the chain and tire. A little close for comfort, but what do you think. Any one please chime in . the more advice I can get the better.
Thanks
Thanks
