chaindrive - 25 pics.
  • xschop
    • Feb 2006
    • 1794
    • oklahoma city
    #91
    spacers
    the spacers can be made from 1 or 2 of the angular contact bearings from the old housing itself...Or I will custom make one for someone's setup. Not a problem...the I.D. would be 30mm IIRC....
    MDRNF
    79F.....Not Stock
    • xschop
      • Feb 2006
      • 1794
      • oklahoma city
      #92
      spacer i.d.
      29.8 to be exact on I.D. You will be able to adjust left or right by about 20mm. This will allow for a number of diff swingarms, Hayabusa, R1, Some Newer CBRs. The key again is the pivot axle diameter mainly and then rear sprocket to CL. I researched The triumph swingarm for weeks before deciding to go with it. The VFR 800 S/A was a go as well but the triumph went too cheap to pass up and it's dimensions are almost identical to the xs11's.....
      MDRNF
      79F.....Not Stock
      • audijunky
        • Apr 2006
        • 707
        • VA
        #93
        I took some pics of my mocked up extended swingarm, still got some work to do but this gave me an idea of what the final porduct will look like
        79 XS1100 modified standard
        straight pipe 4-2 exhaust
        Owned 83 Honda V65 Magna
        Owned 02 Vstar 650 classic
        owned 85 Honda Shadow VT 700C
        • xschop
          • Feb 2006
          • 1794
          • oklahoma city
          #94
          awesome
          Fat is In! ONE question. IF you run a chain from your rear sprocket to the front, will it not interfere with the lower frame tube. If not then, then my spacer would work. HOW WIDE is your REAR TIRE and what's the rear sprocket to CL?
          MDRNF
          79F.....Not Stock
          • audijunky
            • Apr 2006
            • 707
            • VA
            #95
            I dont know about the chain/frame clearance right now, I dont even have one yet. The tire is a metzler me880 200/60/16. My inner edge rear sprocket to c/l is 4.4375" or 112.713mm. Although I may have to push it out a little to get some chain/ tire clearance. Have to wait and get a chain first.
            • audijunky
              • Apr 2006
              • 707
              • VA
              #96
              what size rear sprocket do you have? right now I have a 13 tooth front and a 48 tooth rear. How is that goona ride? I dont know about ratios and all that but I think that it will cruise at speeds with lower? rpms. i really dont know though.
              • xschop
                • Feb 2006
                • 1794
                • oklahoma city
                #97
                clearance.
                when you get your chain and if it doesn't clear that tube you may have to do what I did. it really isn't that difficult. you could even cut it out with the motor still in the frame. I have a 190 stock tire on the triumph and had to do this....also your smaller swingarm pivot area may help you out on your chain clearance too.....chop
                MDRNF
                79F.....Not Stock
                • xschop
                  • Feb 2006
                  • 1794
                  • oklahoma city
                  #98
                  wow
                  are you gonna drag race that thing? 48 rear / 13 front is too low... for hiway. you will be sick fast off the line. I am going to put the 14t on front and have a stock triumph 43t and have the 13t also for around town....
                  MDRNF
                  79F.....Not Stock
                  • audijunky
                    • Apr 2006
                    • 707
                    • VA
                    #99
                    When I take it to the track I guess. I didnt know what size to get at the time I bought the rear. What size rear should I look for highway?
                    • audijunky
                      • Apr 2006
                      • 707
                      • VA
                      #100
                      The wheel I am using has the 5 bolt hole pattern, which a lot of harleys use. I have looked on the bay and they dont get any smaller than 48 tooth. Do you think a 14 tooth front would help?
                      • audijunky
                        • Apr 2006
                        • 707
                        • VA
                        #101
                        Would a 44 tooth rear improve things, I think I found one on Sprocket specialist?
                        • xschop
                          • Feb 2006
                          • 1794
                          • oklahoma city
                          #102
                          ratio
                          to get closer to the stock xs11's ratio. you would need to use the front 14t with your 48t rear and you will still have a lower ratio, but close to 3.3
                          MDRNF
                          79F.....Not Stock
                          • xschop
                            • Feb 2006
                            • 1794
                            • oklahoma city
                            #103
                            keep whattcha got
                            for hiway get the 14t front and 44 rear....PERFECT
                            MDRNF
                            79F.....Not Stock
                            • audijunky
                              • Apr 2006
                              • 707
                              • VA
                              #104
                              right on,
                              for now I am gonna set it up with what I got a see how it rides
                              • xschop
                                • Feb 2006
                                • 1794
                                • oklahoma city
                                #105
                                keep it real
                                keep me posted about the chain clearance underneath....what did the metzler set you back?
                                MDRNF
                                79F.....Not Stock
