chaindrive - 25 pics.
  • audijunky
    • Apr 2006
    • 707
    • VA
    Thank you sir,
    You are a scholar and a gentleman(your the man)
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    • audijunky
      • Apr 2006
      • 707
      • VA
      Was wondering if you knew why Yamaha used the style of bearing they did for the swingarm pivot point? (conical?)and not a regular style ball bearing. I ask because I am going to fabricate a custom swing arm and was planning to use regular style bearings or maybe even bushings.
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        Possibly for centering the swingarm with the least amout of friction. Also to allow for preload, maybe related to it being shaft-drive?
        Just musing here.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • audijunky
          • Apr 2006
          • 707
          • VA
          #34
          Well I just got off the phone with a tech support guy for sprocket specialists.com and I believe we may have found a 13 and/or 14 tooth sprocket to fit our machines. It is a replacement for a 66-69 Honda CB 77. I just got done ordering one for 25.00 and will let ya know if it will work or not. The part # for them is 506-13 if you want to take a look.
          Have a good day,
          Steve
          • pggg
            • 1609
            • NZ
            #35
            Audi, brilliant detective work! Those C77 front sprockets sound like they're compatible, here's a quote from a webpage
            - Sprocket Specialists produces high quality replacement sprockets for most make and model machines. Case hardened and precision cut for excellent fit and finish.
            Fits: Honda CB75 Hawk 1964 to 1966 CB77 1966 to 1969 CL77 1966 to 1968 also fits Yamaha TX/XS650 upto 1983 and TX750A 1973 to 1974
            SS # 506 13 TOOTH Front Sprocket 530 Chain size
            Here's a pic of the C77 pattern, and it sure looks the same as the XS
            • pggg
              • 1609
              • NZ
              #36
              PS the bearing in question is a side thrust bearing that handles the sideways force coming from the right-angle bevel, only needed if running the shaftdrive, there's no torque reaction with a sprocket so a 'normal' bearing does the trick.
              • 50gary
                • Apr 2006
                • 225
                • Saginaw, Michigan. USA Third stone from the sun
                #37
                I've ordered 506 countershaft sprockets from Sprocket Specialists for my XS650 (all models) in 520 or 530 chain. I use 520 X-ring by D.I.D. They list 13T to 18T chromloly steel. On page 52 of my catalog.
                Cheers, 50gary
                • Pat Kelly
                  • 3046
                  • Golden Valley, AZ
                  #38
                  Cheers, 50gary
                  That's a lot of sprockets
                  Pat Kelly
                  • pggg
                    • 1609
                    • NZ
                    #39
                    Yeah I've got 4 of them and I thought that was a lot! Looks like "Sprocket Specialists' are about the only manufacturer to supply those XS650/C77 sprockets smaller than the usual stock 16-17 tooth
                    Good to know I won't have to resort to those rip-off machinists again, although a US$25 sprocket will probably still cost 50$NZ down here.
                    • audijunky
                      • Apr 2006
                      • 707
                      • VA
                      #40
                      Hey pggg, if you think it would be cheaper for me to purchase them, then mail them to you I could do that. If you need any?
                      • pggg
                        • 1609
                        • NZ
                        #41
                        Hey Cheers Audi, actually I've got enough sprockets to last for a few more years yet, but thanks for the offer .
                        • audijunky
                          • Apr 2006
                          • 707
                          • VA
                          #42
                          IT fits, it fits, LIKE A GLOVE.
                          hey PGGG,
                          How did you get the holes lined up on the plate for the extended bolts. I have cut my housing, And traced the gasket on a piece of metal but cant figure out how to precisely figure out where to drill the holes for the outer bearing housing. I am sure they need to be perfect to keep the shaft straight.
                          Thanks
                          • pggg
                            • 1609
                            • NZ
                            #43
                            Matching holes to copy to a steel plate, the holes in the gasket give 4 of them, then a matter of positioning another middle hole to match the chrome cover, the gasket sits in only one position, find that, pinpoint the hidden hole position on the gasket with a ballpoint pen, the chrome cover gives the remaining hole position.
                            Further 4 more holes up front aligned with front engine case bolts, I cut down some 6mm bolts, screwed them into the engine case, painted a tiny thick blob of paint on the ends(dead centre) and unscrewed the bolts slowly a couple of mm's till the paint left pinpricks on the steel plate
                            • pggg
                              • 1609
                              • NZ
                              #44
                              Whoops -
                              • audijunky
                                • Apr 2006
                                • 707
                                • VA
                                #45
                                I guess you didnt use the two holes to the far right to allow for chain clearance? The one with xx on it and the one above?
