Yay! \(^_^)/
FWIW? (*′☉.̫☉)
Iffin yur feeling a bit reluctant to do a total tear down, clean, rebuild, adjust, install, and RE-adjust a set 4 (fower...) Mikuni BS-34 Constant Velcity CaburatatorZ??! ヾ(゚д゚)ノ゛
Then imma gonna say there's prob'ly a good reason on yur side of thingz. (/。\)
I means, ya don't R E A L L Y knows what yur in fOaR and wut to expect OaR DO as it's a "first time thru the Gate" scenario. Iffin that's the case then I heartily recommend you DON'T. Just DON'T. ε=┌(;・_・)┘
There's only so many of these carb banks left and nobody wants to see the bank (and therefore the entire bike...) useless cuz of ruining one....just ONE carb body due to being HAMHANDED 'bout removing a float post, jamming the wrong size screwdriver into the pilot air jet hole and cracking the horn, OaR boogering up the idle fuel screw tip/hole. (-‸ ლ)
I would totally support you taking NO action at all considering at this moment yur deciding NOT to do anything cuz you KNOW that you DON'T know wut you NEED to know. (︶︹︺)
BefOaR making a final decision to act OaR not to act? (O_o)
You might find the following useful-
https://xs11.club/forum/repairs/carb...b-cleaning-101
https://xs11.club/forum/repairs/carb...-1980-81-carbs
This video channel has the mostest detailed and useful videos in this area that I've EVER seen and I've used them as my own guiding light.-
Know befOaR you go.... ( ゚_ゝ`)
OaR DON'T go if that ends up being the case. ¯\_(°_°)_/¯
So ...need a bit of direction-was carbs, not coil pick up
Jets-R-Us is a good source, just make sure you're purchasing OEM brass. They also offer aftermarket carburetor parts."Has anyone a source for OEM?"
Yup! (^_^)
OaR at leat I thimk I do.... (O_O)
Nice Cycle Supply is another good source. Genuine Mikuni Replacement Parts and Tuning Components
Here's another gold mine. The 1980-1984 XS650 have BS34 carburetors very similar (not the same) as on the XS11. In the link you will find all kinds of goodies such as o'rings, fasteners, and Suzuki branded parts that are identical to Yamaha at a better price.
(11) The great o-ring, seal, gasket, nut, bolt, sizes used on the XS650 thread. | Yamaha XS650 Forum
Leave a comment:
Both you guys with leaky carbs want to make sure the oil in the crankcase didn't get thinned out from excess fuel spillage.Leave a comment:
Nope! I think this is the correct needle valve seat Oring?BSR-36 Float needle valve seat 7.5mm I.D. x 1.53 mm Leave a comment:
Changing parts is only half the job. You *MUST* set those float heights with the method shown in this forum topic. And follow with a sync. Skip any step and your bike will run but not run right.Leave a comment:
Thanks Larry."Has anyone a source for OEM?"
Yup! (^_^)
That's where's I orderered all of the parts I needed to replace the the stuff from the Chinee/Taiwan Kits I bought/installed frum Flea-Bay. (_Oo)
I M P O R' U N T- Jets-R-Us anint the most user friendly website so's you gotta already KNOW details you'd N E V E R know about yur carbs unless you HAD to know....., Y'know? (╯•ᗣ•╰)
Fortunately, the info to get you started in yur seach at JetrUs is right here-
Good Hunting! ( ˘▽˘)っ♨
So I'm thinking shouldn't I just replace the "jet needle o-ring"...since that's the culprit of the leaking?
Otherwise I'm better off having someone competent rebuild the things rather than me trying. I also will probably have an actual physician remove/replace any of my parts as I've no experience with that, either. lol
Anybody here do such a thing? Obviously it ain't free. I'm aware there'd be parts and labor costs.
Leave a comment:
Yup! (^_^)
Good Hunting! ( ˘▽˘)っ♨Leave a comment:
OK. I've read, before, of the debacles caused by chinee *rap parts, so yeah, that much I understand.
"Well Jonny, your 81 carbs use an O-ring to hold the needle seat in, when one goes, fuel will leak past and end up in the air box and/or the crankcase." THAT'S what I was hoping to read- the most likely cause. TY.
"I would first try tapping the side of each carb bowl with a screwdriver handle to make sure the floats aren't stuck and easily freed." Probably should have. Too late for that now. They're off the bike. The first time it happened when I returned several hours later I expected the bogging to still be a problem yet it fired up and got me back home like normal. It was every subsequent ride, after that that continued to be an issue and where I checked the pickup coil wiring and replaced the battery which solved the tach intermittent function issue.
If that does not solve the problem, you would remove the carbs, take out the floats and examine the float valves.-will do. If you find crud, maybe you can clean them. Perhaps you would decide to replace the needles and the seats while you are in there. In either case, measure the float height and adjust as necessary."
Is the "seat" the gasket Bikerphil referred to? What would one use to clean the needles?
THANKS GUYS!
For your amusement:... I thought, " I'll remove the entire air cleaner box to make it easier to get the carbs off!". HAHAHAHA! Nope. What a PITA. Couldn't get it out, past the carbs. *RAP!
Got the carbs off and finally managed to get the box off. YAY. Then when I got it out and turned it over all the fasteners began to fall out as I had also removed the bracket which holds it onto the frame.
You would have enjoyed watching me try to get it all back together.
By the grace of God, ONE of the long brackets which is connected to and held in place by the bracket did not fall out or I would have had NO IDEA how and where each piece went! AS it stands I seem to have three, not four, of the "rubber oblong vibration washers" with the brass pieces in each end. I had a picture that did show show two were between the bracket and the airbox. The third? Not sure. Where the hell is the fourth one!?
Leave a comment:
I would first try tapping the side of each carb bowl with a screwdriver handle to make sure the floats aren't stuck and easily freed.That there was. Twice. First time I thought I had flipped petcock incorrectly. THis time there wasn't a question as they were just at "ON" as I have always run my bike and I could see the drip and the fuel stain on the garage floor.
Might I ask you what you'd suggest to cure that? The repair?
TIA
If that does not solve the problem, you would remove the carbs, take out the floats and examine the float valves. If you find crud, maybe you can clean them. Perhaps you would decide to replace the needles and the seats while you are in there. In either case, measure the float height and adjust as necessary.
Bikerphil made an important reminder.Leave a comment:
Leave a comment:
FWIW....꒰(・‿・)꒱
The carbs pictured in the "Carb Pagoda" ain't held up to the crossbeam by magic oAr magnets. (⇀‸↼‶)⊃━☆゚.*・。゚
I used reg'lar ole bailing wire but where's it threads thru the carbs/bracket Kan't be seen cuz it's behind the yellow tygon fuel lines/filterz. (⊙ᴗ⊙)
Now-a-dayz I've upgraded to usin' these thingies bought at Lowes Hardware section....
A bit mOaR secure/safer than bailing wire as each time you Test and find the level(s) ain't wheres you need'em to be? (o_O)
You gotta drain the bowls and flip the carb bank upside down (again...) to measure/adjust the float tab(s). (_Oo)
The large hose clamps just wurky better. (^_^)Leave a comment:
Eek!!! ( ⁰д⁰)
Iffin the fuel overflowed outta the carbs to the point where's it went backwards into the airbox (which on MY Special is actually uphill from the carbs even tho's the bike is on the centerstand and on level ground...) ╭(°ロ° ”)╯
Then it's wurth'a look see into yur engine oil to find out if and how much fuel made it into the engine as on my bike the intake booties and inlets are downhill/downstream of "overflowing" carbz. ( º﹃º )
Well.... (O_o)
U N L E S S you do wut I do which is put a 2x4 under the front wheel every time I park the bike overnite on the centerstand. (๑•́ ₃ •̀๑)
Allz bets are off iffin you only use the sidestand.... (´・_・`)
Leave a comment:
Leave a comment:
