Hey Nzemke,
Brant keeps talking about having to get the 1.5 ohm coils for your/early model XS11, but that's not entirely so. The later model XS's went to the 3.0 ohm coils and got rid of the ballast resistor, so the TCI still sees the total 3 ohms resistance on the triggering side.
SO...as we have stated many times, just get some 3 ohm coils and BYPASS/REMOVE the ballast resistor and you'll be good to go, and you'll have coils that will provide full spark power ALL the time. The 1.5 ohm coils with the ballast resistor in circuit only run on 12 volts during startup, once the bike is running, the power is directed thru the B.R. which drops the voltage down to about 9 volts. This was to keep from frying/overheating the OEM 1.5 ohm coils, but also causes them to produce less/weaker spark energy since running on lower volts. Bypassing the B.R. sends 12 volts to the coils ALL of the time which will provide a stronger spark ALL OF THE TIIME, not just during starting.
The 1.5 ohms coils are so passe`, just find some newer 3.0 ohm coils whether they be used Honda VFR coils or new aftermarket, bypass the B.R. and you'll be good to go. You'll be surprised at how quickly/easily the bike starts....mine actually felt like it would ROAR to life and not just "start" because of the extra strong spark energy!
more work to do this Spring!
which I will check tonight when I get home! And I also picked up a round xs special round Tach for the bike...so I can get rid of this cheap 1:1 china crap. Now I need to make a bracket so the gauges are recessed more and not stuck up so high. With these euro style handle bars the gauges look a little funny when they are that high.
I was using a brake cleaner and a carb pick for cleaning the small hole
