  • xs11lover
    • 1433
    • Montoursville Pa
    #3196
    Washed them up for a cold weather break!
    79 XS11 Special (Lazarus)
    79 DT 100
      • 6762
      #3197
      Gave mine its last rites...this sucks bigtime....
      • MarkD
        • Jun 2013
        • 488
        • N. Michigan
        #3198
        I put the old girl to bed. Was 43* out, so I did the ATGATT thing with my brand new hi-vis yellow helmet and had a nice run. When I got home, I put in the startron additive and covered her up in her blankie. This was only the 2nd ride of the year due to circumstances beyond my control. More riding next year for sure.
        79 F
        1967 Suzuki X6 Hustler
        1973 Suzuki TM 125
        1979 XS1100 F
        2005 Kaw. Vulcan VN800
        1991 BMW K75
        • XJkid
          • Jun 2003
          • 280
          • Elk Grove, Ca.
          #3199
          shim
          I did a valve adjustment a few months ago and had a pronounced clicking on the right side. I figured I did a boo-boo but wasn't too concerned. I took it apart Saturday and found that I probably applied the exhaust specs to the #4 intake and had a .265 shim installed when I should have had a .275. Got the right one in and it now has just the right amount of noise. The last time I did the valves, I had the cams out, so I didn't need to use the shim tool. It has been a few years since I had used the tool and forgot that the valve needs to be depressed by the cam beforeinstalling the tool. I sat there for 30 minutes trying to figure out what I was doing wrong before breaking down and looking in my manual.
          • Crooked_Fender
            • 29
            • Milwaukee
            #3200
            Grumble, grumble...
            I kicked it as I briskly walked past it while thinking about the top end rebuild I'm going to have to perform because I'm an idiot who can't read instructions.
              • 2083
              What happened, valves, piston, rings ?
              Did you end up leaving the middle drive in, reinstalling the bolts and servicing the oil through the drain plug ?
                • 9980
                Went out and blew the dust off today.
                  • 5062
                  #3203
                  Greg, I wish I could have gone for a ride today. Too much snow on the road...
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Led
                    Recently finished total bike LED conversion. Not a single incandescent bulb left on the bike. Even the instrument bulbs are LED. Used member Ted's "magic" LED flasher that allows use of LED bulbs while retaining auto-cancel feature. Test rode bike and all went well. Auto cancel worked flawlessly. My alternator and battery were smiling the whole time. No more light dimming or slowing t/sig flash at idle. All LED bulbs were obtained from Superbrightleds.com.
                    Mike
                    1981 XS1100H Venturer
                    K&N Air Filter
                    ACCT
                    Custom Paint by Deitz
                    Geezer Rectifier/Regulator
                    Stebel Nautilus Horn
                    EBC Front Rotors
                    Limie Accent Moves On In 2015
                    Mike
                      • 5062
                      #3205
                      Nice! So did you need load resistors?
                      • MPittma100
                        • Aug 2011
                        • 2359
                        Flasher
                        Replaced OEM flasher with Ted's flasher. Was a plug and play deal. Not sure how it works, but it works. Did not have to add resistors, just plugged it in.
                        K&N Air Filter
                        ACCT
                        EBC Front Rotors
                        Mike
                        • puskrat
                          • Jun 2015
                          • 312
                          • Peoria IL
                          #3207
                          That sounds extra nice
                          "Venturered" 80 XS1100G - "DoraMax" getting sort of resto/destro ed.
                          Yeah it's a pretty blue, but just because you're old is no excuse to buy a bagger. Fortunately I have wrenches.
                          • dbbrian
                            • May 2016
                            • 596
                            • Stratford, Ontario, Canada
                            #3208
                            Can't find Ted on here. He sells flashers?
                            • MPittma100
                              • Aug 2011
                              • 2359
                              Ted
                              Will track him down.
                              K&N Air Filter
                              ACCT
                              EBC Front Rotors
                              Mike
                              • MPittma100
                                • Aug 2011
                                • 2359
                                Flasher
                                Contact member ELDR (Ted) about his flasher unit. Allows conversion of t/sig bulbs to LED and retains auto-cancel feature.
                                When you change to LED bulbs, you must also change flasher to LED type. Standard LED flasher does not retain auto-cancel. Ted's will.
                                If your bike has factory emergency signals, you must change out that flasher with an LED flasher too.
                                When purchasing LED bulbs, you must match bulb color to lens color.
                                Mike
                                K&N Air Filter
                                ACCT
                                EBC Front Rotors
                                Mike
