    Lookin' good again with the hard cases all mounted! See you musta' been at the point a 'cold one' fit the hand better than wrenches did anyways.
      • 9980
      Yeah, these bags are a little bigger and are a bit more useful.
      Gotta take those XJ shocks off and rebuild them AGAIN. They're leaking all over the rear brake AGAIN! Got some different seals this time. Those LeakProof seals are garbage.
        • 3918
        I guess they are spot...but i like them..I need more adjustments to get the proper light pattern but i am most primarily concerned with being seen than actually seeing with them..but as they sit I am quite pleased with them...They have to be ordered from China and they takke about a month to get here...But for 24 bucks you cant beat 'em
        Ahh. I had the newer model, and will replace them with floods, like on my XS.
          Bummer on havin' to rebuild those shocks.......again! FWIW, found through conversation among riders a decade ago when still involved in the moto-x world the LeakProof brand seals were exactly as you stated. Got faith in ya' buddy, you'll get that resolved.
            • 6760
            #2975
            Looking real good Greg...how many miles do you suppose those XJ shock have on them before the seals failed? BTW thats one serious topbox...nice
            one more thing how much air pressure do you use in them? Just curious..i keep mine at about 30psi
            1980 XS650G Special-Two
            1993 Honda ST1100
            • hamjam
              • 1003
              • Toronto ontario Canada
              #2976
              nothing at but i did do setups on 2 basses and a gretch 6 string that ok ?
              Seamus Ó hUrmholtaigh
              Niimi Moozhwaagan
              and SOXS
              2008 Nomad "Deja Buick'
                • 9980
                I don't know how many on the original seals but the LeakProofs didn't even make it a season....TWICE. Gonna try some Emgo this round.
                That's the same trunk I've had for 3-4 years. It's detachable and I use it for a suitcase on trips so you never see it on a ride. Just when I arrive or leave.
                I run 30 usually but bump it to 40 when the bike is loaded down.
                  • 6760
                  #2978
                  Hi Jim...Good to seeya here...
                  1993 Honda ST1100
                    • 6760
                    #2979
                    Greg...last season when Mark and i installed my set of XJ shocks that we rebuilt... they worked at first then wouldnt hold air and was leaking fork oil on the right shock...turned out there was a nut/bolt on the frame that was too long exerting pressure onto the side of the shock causing it to misalign internally and caused the oil to pass the seals... there was visible gouge into the side of the shock...so check to be sure nothing is pressing on them...
                    1993 Honda ST1100
                      • 9980
                      I'm sure Ben. The only clearance issue I've had since I switched to the XJ shocks 5 years ago is the mount for the rear brake hose rubbing a hole in the dust cover. Fixed that.
                        • 7814
                        Just a thought guys. How about new shocks? Technical improvements have been made since 1982.
                          • 6760
                          #2982
                          Hi Marty...at what cost?
                          .the xj shocks are a cheap fix that works fine...
                          1993 Honda ST1100
                            • 7814
                            You're right, Ben. Go back to the junkyard.
                              • 6760
                              #2984
                              Well...im not the first and not likely to be the last ...whatever works for you...so if new expensive stuff floatsyour boat then by all means have at it...and tell me pls...what is wrong with recyling reusing and refurbishing old parts? Why dont we all just scrap thesr old bikes and just buy something new? Unless u r teasing me again..i find your statement somewhat arrogant
                              1993 Honda ST1100
                                Don't see that at all Ben.........bettin' getting moved to Tuscon will lighten you up. Besides, doing that will give ME closer, better opportunity to pick on you.
