  • nzemke
    • Sep 2012
    • 179
    • Moses Lake, Wash.
    #2296
    lol, indeed! So she got her first full tank of gas in a little over 12 years I figured out how to properly adjust the carb pressure gauges so you can get a clean reading and it made a HECK of a difference!! Also after much swearing and cursing I was able to resolve my stripped bolt on the exhaust pipe. Took her for a mile drive down the road to the gas station and aired up the front tire....but the adapter they have on it was to awkward and wouldn't fit into the back tire to fill it up. Otherwise there are a few little things that will need to be adjusted but she sounds so good at idle!
    79F with two parts bikes (78E and a 79F). Ran it for the first season all the way through the summer. more work to do this Spring!
    • tcoop
      • Nov 2009
      • 793
      • South Weber, UT
      #2297
      striped my 78 tank and applied primmer
      Then I put a forest green on it
      I plan on adding this to it
      hopefully I will be able to do it justice.
      Ty
      78 XS1100E - Now in Minnesota
      80 XS1100LG - The Punisher
      82 XJ1100 - Daughter's Bike
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        #2298
        Yesterday and today,
        Replaced rear tire and battery. Fresh fuel, rode the E to work (where it will sit until Tuesday).
        Haven't ridden it in 3 years.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
          Good to hear OTR has finially left you some time to re-aquaint yourself with the scoot Pat.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            #2300
            Not really 3,300 every week.
            It was fun riding to work though
            Btw, anyone along I-40 through CA, AZ, NM, up US-54 through TX, OK, and KS... watch out for my truck
            Pat Kelly
            • Crusty Snippets
              • Sep 2010
              • 428
              • Gabriola BC
              #2301
              Side car
              Had the side car on for a week. Loaded with two sails for the boat. Side car sagged on 140 mile round trip. Made changes to how " Inder " is bolted to Yami. Studied Fred in Toon's photo. Was the mount next to the RH foot peg that was the problem. It now goes under the peg. There is enough room for the brake lever to operate. Also connected the steering damper and moved the rig back 1 1/2 inches, and checked the toe in. Still a bit heavy to steer but much better.
              Rode down to boat yesterday and smoked a Harley on the way.
              Unkle Crusty.
              • TomB
                • Aug 2006
                • 967
                • Cumbria, UK
                #2302
                Welded up my Kerker collector box today and gave the whole thing a coat of heatproof paint.
                Tom
                • STEPPENWOLF
                  • Jan 2007
                  • 4188
                  • CINCINNATI OH
                  #2303
                  Said happy birthday to my bike. Had it 34 years now We had some ups and downs,some bumps in the road but we managed to stay the course and ride thru all the rough times.
                  '80 XS1100 SG
                  • tcoop
                    • Nov 2009
                    • 793
                    • South Weber, UT
                    #2304
                    Tried to start the 78E it would only spark after I let go of the starter button. Checked the pickup wires two were broken Fixed those and the bike fired right up. Now to start making it look good and finish the assembly.
                    Ty
                    • tcoop
                      • Nov 2009
                      • 793
                      • South Weber, UT
                      #2305
                      Got the 78E to run and idle and did not have to make adjustments (other than a longer throttle cable) fond that the newly painted tank still leaks even after using a tank liner. good thing it was only a rattle can job.
                      Ty
                        I put the clutch in this afternoon but I'm not sure what's up with the new Barnett springs.
                        The Barnetts are definitely taller than the OEM springs and everything I read had me expecting to have to wrestle with the star plate to get the bolts started but there was no such problem. Even the first bolt was easy to start and and the rest of the bolts followed along like puppies.
                        I use a 14" extension with a 10mm socket to slowly hand-tightened the bolts 1/8 to 1/4 turn at a time in a star pattern until they seated. Not a problem, that's how I did it with the OEM springs too.
                        I removed and replaced one bolt at a time to add a dab of Blue Loctite, then torqued them all in the same star pattern to approximately 86.4 in/lb. Yes, the clutch is slightly harder to pull but it's not at all what I was expecting there, either.
                        The test ride was good; no oil leaks; no clutch slippage; didn't fall on my ASCII going out of the driveway -- I'm sotally toked! :-D
                          • 9980
                          Not sure the Loctite was a good idea on those bolts Scott. I've seen them break but never back out and it may be an issue if you need to remove them again for some unforeseen reason.
                          Your clutch pull should be slightly harder with the Barnetts.
                            • 3932
                            I definitely had issues getting my star plate on with that first bolt. Felt like there was no way in hell it was going on. But, eventually it did, and the others followed. I did not torque them either, just cranked them down, then just till I felt comfortable and nothing more. First pull of the clutch was painful, but not it feels just like the old springs.
                              Thanks, Greg!
                              I was expecting to have to use a digging bar for a lever or hook up pulleys like a compound bow or something to set up the bolts but it's not bad at all. The Barnetts were just as easy to start and tighten as the OEM springs so I'm kind of baffled about why people have said they had problems starting the bolts. <shrug> Clutch pull isn't bad either and my left hand's been half dead for well over a year now; can only use two fingers for the clutch.
                              Blue Loctite? Nah, no problem there, I used it on the clutch bolts "just because" the last time I was in there. There was some used-to-be-blue plastic "stuff" that came out of the threads when I pulled the bolts but I just chased the holes with a tap, then slathered everything with brake cleaner to get rid of the oil and the leftovers.
                              I use the Blue on the two large Phillips screws for the clutch adjuster cover too but I haven't locked them down yet in case I have to go back in and reset the throwout bearing clearance once the clutch is all settled in to its new happy home.
                                • 9980
                                The plate will tilt just enough to get one started and then you can use that one as a fulcrum to get the one opposite started. A breeze from there on.
                                Yeah, the pull feels really heavy to begin with but as you get used to it you don't notice. If you get on someone else's bike without them it feels way too soft.
