    • 9980
    IMHO the float level, idle mixture and sync would be the place to start.
    BTW moto, the vacuum advance doen't come into play at idle so they would have to rev it to make it move. Unless it was running so badly that the idle had to be set up so the butterfly uncovered the vacuum oraface in the carb.
    • Brent
      • 959
      #1487
      Easy quick & cheap
      Filters;
      I got this advice from a wise old mining engineer. "For any motor not running right - change the filters...usually corrects problem, and even if something more is needed, filters should be serviced periodically anyway."
      I had a dodge 318 cu in motor that failed emissions due to too many hydrocarbons. I changed air filter. It went from just failing to barely passing
      good luck wrenching
      Brent in GA
        • 9980
        Good point Brent. An air filter on a carbureted engine will make a world of difference.
          • 2072
          One of my XS-Mas presents
          Shelf bracket mounts
          • Aches n Pains
            • 349
            • Reston, Va.
            #1490
            Nice job and thanks for the pictures. Thanks.
            How are they working?
            Aches n Pains
            1995 KZ100P
            Pods, jets, pipes, cam adjuster, oil cooler
            1977 Ironhead - custom build
            Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
            Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
              • 2072
              Aches n Pains
              Thanxs, I will let ya know how they work in about a month give or take.
              I haven't had this bike in one peice since '01. Found this site in '05 and slowly but surely I am getting all my ducks in a row to have Her on the road this Spring.
              • Poprock
                • Apr 2005
                • 594
                • Oregon Coast
                #1492
                Great looking motor. Excellent cleanup on it. I think you're going to be pleased.
                • Brent
                  • 959
                  #1493
                  Thanks, but before I begin to look too smart... a story - When a fuel filter on my HD road king became partially clogged, what did I do?? Took it to Durango HD...no filter replacement, they broke a wire to fuel injector, assured me that fuel filter, pump etc were all fine since it passed a pressure test, fixed the wire, gave me a place to sit while my riding buddies rode the Million Dollar Hwy (yes it really is paved with gold).
                  I limped back at legal speeds all the way to GA and replaced the fuel filter myself later. No more leaning out at high speed cruising or prolonged high fuel demand situations. Just changing the filter was much quicker and cheaper than work by Durango HD (: ,,,and it FIXED the problem.
                  Today I Rode and charged battery on another. Used 3/4 amp automatic charger.
                  Brent in GA
                  • Petersg_99
                    • Apr 2012
                    • 184
                    • Phoenix, AZ.
                    #1494
                    The vacuum advance was stuck at 20 deg advance, so that may have been the complete problem. I need to get the timing reset, adjust the carbs and try running it through the emission test again with just that fix...
                    Guy
                    1980 XS1100G - Frankenstein - resurrected from the impound lot
                    1991 Suzuki GS500E (not running yet)
                    2003 Burgman AN400 - Blue Belle
                    2005 Burgman AN400 - Silver Belle
                      • 9980
                      Was the plate rusted or the diaphragm stuck? I've never seen one stick in the advance position before.
                      Is the centrifugal advance moving freely?
                      • Petersg_99
                        • Apr 2012
                        • 184
                        • Phoenix, AZ.
                        #1496
                        The plate was corroded. The diaphragm was fine. I disconnected the diaphragm, sprayed silicon lubricant on the plate and exercised it several time until it moved freely, hooked the diaphragm back up and everything started working the way it was supposed to...
                        Guy
                          • 9980
                          Funny it stuck in the advance position.
                          Just from experience I would recommend spraying a rust dissolver like WD40 the equivelent and working it and even let it sit for a while. Clean it out and repeat. Then the silicone.
                          If it was rusted enough to stick in the advance position, against the pressure of the return spring in the diaphragm, there is going to be some fairly heavy rust in there. If it doesn't work smoothly holler and I have several breaker plates laying around here. I'll send you one.
                          You never did answer about the centrifugal advance. Is it free?
                          • Petersg_99
                            • Apr 2012
                            • 184
                            • Phoenix, AZ.
                            #1498
                            If I remember correctly the timing changed as rpm went up even with the vacuum disconnected, that's due to centrifugal advance unit correct?
                            it's going to be a few days to a week before I can get back to it...
                            Guy
                              • 9980
                              Sounds like it's working. You should be able to turn the reluctor by hand with the engine off too sand see if it's working freely.
                              • conquest87tsi
                                • Jun 2012
                                • 190
                                • Jackson, Minn.
                                #1500
                                Schming
                                I mounted my dyna coils in a very similiar manner a couple months ago. I really wanted them to mount in the stock locations. Not sure if you had to remove the horn, but I did. Probably not smart, but I have hated horns since I used to always hit it when I cancelled the turn signals on my VTX.
                                Yesterday I adjusted valves on both my F and SF, kinda. Was able to get shims from the local Kawi dealer for $3.50 a piece! When he grabbed his book for pricing I was thinking "damn, guess I'm ordering online and waiting a week". But to my surprise $3.50! So I only needed four for the F, and by the time I had the SF checked they had closed. I was able to get 7 adjusted on the SF with shims from the F and a parts bike. So just need to add one shim tomarro night.
                                Decided to polish the valve cover while it was off. After 45min of wet sanding I decided to paint it. I polished the timing cover last summer and it took 5 straight hours. 400 grit, 800, 1000, 1500, 2000, 2500, rubbing compound, polish. Didn't feel like spending 12 hours on all the contours of the valve cover. Going to paint it Gold. Should look good with the emerald/ gold tank and side covers and gold carb diaphram covers.
                                1979 XS1100 SF
                                1979 XS750 SF
                                Previous Rides:
                                1981 KZ650CSR
                                2006 VTX 1300C
                                1986 Radian 600
