    #1036
    Cleanin'....
    Finally took the E 'modder' frame to the powdercoaters', dug the motor I'm going to use in it out and started cleaning it...
    [IMG][/IMG]
    [IMG][/IMG]
    This thing is nasty; it looks like the PO ran it (for a while...quite a while) with a leaking CCT, and to add insult to injury, ran through some fresh road oil somewhere along the line; I found more than a few chunks of gravel stuck to the front. And never cleaned any of it off... it's thick and baked on...
    It checked really good; compression was between 190 and 200 in all cylinders. After I get the big chunks off, I'll adjust the valves, install an auto CCT, and pull the pan to look at the gear dogs in the trans.
      Checking the center stand welds didn't help
      Today I rode to the welding shoppe' but I forgot it's a holiday so no one was there but me.
      There is rust on the top of the weld that used to hold the left-hand center stand bracket to the frame. The upper flat part of the bracket fits up against the frame tube but there is a small gap where water can get between the bracket and the frame and you cannot see the weld.
      I had been checking the center stand brackets and other frame welds when I put air in the tires but there was no sign of any problem at all until the hidden part of the weld broke. The center stand collapsed as I was kick starting the engine and the weld on the right-hand bracket popped cleanly out of the frame as the stand folded forward and the bike fell over.
      The center stand is spider-bungee'd to the luggage rack for now so I took a picture of the left-hand bracket. You can see corroded metal on the hidden side of the weld and clean, freshly broken, metal and paint on the other side.
      I haven't taken any pictures of the holes in the frame or the right-hand bracket.
      • planedick
        • Mar 2005
        • 2068
        • Yorba Linda, California
        #1038
        Bad weld
        Looks like you better find a better welder...
        Drilled airbox
        Tkat fork brace
        Hardly mufflers
        late model carbs
        Newer style fuses
        Oil pressure guage
        Custom security system
        Stainless braid brake lines
          Yes, the Yamaha factory line-chimp struck again so that's Plan B and until it's done I'm riding Shank's Mare.
          The P.O. literally ripped out the center stand on Bush, the '79 Special, so Plan A was to get new brackets welded on before tearing down Columbo to fix the engine. Now both of the frames have ragged holes in them so I can't ride either one.
            Looks like weld was fine as it pulled base metal when it came loose............comes in threes 3Phase........JAT........
              "Just one more thing...."
                ...........that STILL comes in threes............
                  Lately it's been several sets of threes... even the cats are starting to hide!
                  • Gearsnd
                    • 43
                    • fargo, North Dakota
                    #1044
                    elbow grease
                    https://
                    a bit of elbow grease goes a long way.
                    https://
                    oh and i got to ride yesterday by freak chance. the ice and snow melted just enough to get both my XJ550 AND cool toms old my new XJ1100 out to the open interstate for short ride yesterday. oh and btw tom you weren't kidding when you said take it easy with second gear lol. cool tom you have taken great care of that bike but she still needs a bit of care yet. i am looking forward to making it the best it can be.
                    if it has screws in it i am gonna screw with it!
                    82 XJ1100 "the red baron"
                    82 XJ550 "max"
                    82 S10 not quite right pickemup "lucy"
                    73 honda 750
                    • ddragon63
                      • Jan 2012
                      • 1101
                      • Ridgefield, WA
                      #1045
                      Rode "old man' into town to the grocery store after work.... haven't ridden it since I adjusted the valves last weekend. Runs soooooo much better
                      It was 36 outside but rodes were dry... thank god for cold weather gear
                      Don
                      old:
                      1989 kawi ex500
                      1996 yzf-r6
                      1999 yzf-r1
                      2001 kawi zx-6r
                      2000 Ducati 748
                      2002 YZF-R1
                      2005 V-Star 1100 Classic
                      • slow mo
                        • 858
                        • ontario canada
                        #1046
                        tightened loose motor mounts// installed green coils// replaced most big electrical connectors with soldered joints and heat shrink wrapped// carbs cleaned ans synched// installed a Tkat fork brace// changed the oil // praying for an early spring!!!!! ride safe ,,slow mo!
                        moemcnally@hotmail.com
                        i AM THE KING OF NOTHING
                        • tweeleft
                          • May 2009
                          • 110
                          • Bend Oregon
                          #1047
                          Installed new valve cover gasket, changed out cam chain tensioner for a Raptor auto style, rejust carb slide needles again, Carb sycn, Colortune, New bolt in airbox(lost going down the road). Man I love these bikes
                          Keep the shiny side up
                          1979 XS1100SF
                          Mac 4-1
                          Drilled airbox Uni filter
                          Vmax bars
                          Virago 1" shorter shocks
                          30K miles
                          http://i1228.photobucket.com/albums/...429_135845.jpg
                          1981XS1100SH
                          '80 G Forks and Triple Tree
                          '80 G tank
                          Mac Turnouts
                          Virago 1" shorter rear shocks
                          SH Headlight
                          http://i1228.photobucket.com/albums/...psd6adaae1.jpg
                          61 Wife
                          83 Son
                          86 Son
                          89 Daughter
                          • Pat Kelly
                            • 3046
                            • Golden Valley, AZ
                            #1048
                            Uncovered the E and pushed it from the driveway to the backyard and recovered it. Haven't rode either bike in a year.
                            I should sell them.
                            Pat Kelly
                            <p-lkelly@sbcglobal.net>
                            1978 XS1100E (The Force)
                            1980 XS1100LG (The Dark Side)
                            1999 Suburban (The Ship)
                            1994 Dodge Spirit (Son #1)
                            1968 F100 (Valentine)
                              • 9981
                              Why not Pat?
                              • Cuda 69
                                • Jan 2012
                                • 676
                                • Greenwich N.Y.
                                #1050
                                replaced the front brake master cylinder today with a new one,man am I having a h*ll of a time bleeding the brakes,even using a mity-vac. time to take a break.
                                FOXS-XS11SG
                                1980 XS11SG-sold
                                1999 Vulcan classic-sold
                                1982 XJ 650-sold
