Set and forget tensioner (For XJs too)
  • newtoXS11
    • Jul 2010
    • 29
    • Green Bay, WI
    #76
    What was your ebay search? I'm set to be notified with the search string:
    venture tensioner -chevy -chevrolet -belt
    and haven't had a single email in over a week.
    • nutwister
      Xsive
      • Jul 2010
      • 38
      • Planet Earth
      #77
      Originally posted by newtoXS11
      I can't find one of these anywhere. Can someone either be kind enough to share a spare (I know some of you guys got two) or at least find a link for me? I know these things are pretty cheap - I'd be glad to buy one for $20 which should more than cover what some of you paid for two of 'em...
      JAT!
        #78
        Originally posted by nutwister
        Oh you stole my post! I was going to post it here but just never got around to it. I guess I could do that tonight.
        There now its posted here as well
        • Pat Kelly
          • 3046
          • Golden Valley, AZ
          #79
          I would look for "Venture cam chain" and "Vmax cam chain". Took a while but found the right deal
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
          • Toolmaker Tim
            • 671
            • South Bend, Indiana
            #80
            CCT Search
            When you do your search for "venture cam chain" or Vmax cam chain", also try "xvz1200" or "vmx1200" cam chain. Also, if the seller is a wrecking yard, email him and ask if they have the tensioner. They may not have listed it and if you ask they will let you know the listing number. Thats how I got two of them for $7 apiece. Especially ask if they have the cam chain guides listed.
            1979XS1100SF
            K&N's and drilled airbox
            Jardine 4in1
            Dunlop Elite 3's
            JBM slide diaphragms
            142.5 main jets
            45 pilot jets
            T.C.'s fusebox & SOFA
            750/850 FD mod.
            XV 920 Needle Mod.
            Venture Cam Chain Tensioner
            • 81xsproject
              • 3185
              • Fortuna, CA
              #81
              The secret is to read up on eBay's search hints. I like to try and get it all in one shot. If it's a long, complex word, I even try to guess some common misspellings sometimes. This whole thing below is a good start;
              (vmax,v-max,v max,venture,xvz1200,xvz 1200,vmx 1200,vmx1200) (tentioner,tensioner,chain)
              Happy hunting.
              '81 XS1100 SH
              Sep. 12th 2015
              RIP
              • newtoXS11
                • Jul 2010
                • 29
                • Green Bay, WI
                #82
                Thanks for all the advice. I pride myself on knowing how to use search engines to find pretty much anything the first time I search for it. That said, I give up. In the last week I've talked to over two dozen salvage yards and other douchebags who want $70 or more for just one of these things and it's just getting ridiculously frustrating. Realistically it only takes about five minutes to adjust the cam chain tension and I can't imagine needing to do it more often than once every season.
                WHEN one of you ends up with a spare auto tensioner let me know. I'm done playing this stupid "hide and seek and haggle" game.
                  #83
                  There are 2 vision 550 tensioners on there for $9 right now a few more for a little more money but most expensive one is $25.
                  http://cgi.ebay.com/ebaymotors/82-xz...Q5fAccessories
                  Just shave off a tiny bit of metal in one of the holes and she goes right in just right.
                  • Geezer
                    • May 2003
                    • 2985
                    • Willamina, Oregon 97229
                    #84
                    I have to find it but I have a 550 Vision tensioner that I'll let go for postage. I just need to make sure it's not my venture tensioner first...
                    Geezer
                    • 81xsproject
                      • 3185
                      • Fortuna, CA
                      #85
                      Here's a question. In the search for alternate auto CCT's, does anyone know of one that has a wider bolt pattern? I realize the Vision is slightly wider, but it doesn't sound like it's too far off and doesn't look to have much outer meat to spare around the bolt holes. I want one for my buddies kz1000 and it's probably a good 5mm wider.
                      '81 XS1100 SH
                      Sep. 12th 2015
                      RIP
                        • 7821
                        The outer metal does NOT hold the tensioner down. The metal near the center is what holds the tension, and keep things together. I've seen a LOT of parts with slots, not tight holes, for mounting. Look for something close, and worry about the center and gasket fit.
                        • barberad
                          • 416
                          • the 45th state
                          #87
                          See my C
                          Originally posted by cajun31
                          Of course you need to make sure you have the motor rotated around to the C mark before installing.
                          Where do i find this "C"? I've got the tensioner, but if this can be screwed up, I am the one to do it.
                          Thanks,
                          Dan
                          Current Rides: '82 XJ w/Jardine 4-1's, GIVI flyscreen, '97 Triumph Trophy 1200
                          Former Rides: '71 CB350, '78 400 Hawk, '75 CB550/4;
                          while in Japan: '86 KLR250, '86 VT250Z, '86 XL600R, '82 CB450(Hawk II), '96 750 Nighthawk, '96 BMW F650
                            #88
                            Hi Dan,
                            If you pull the timing cover off, its the one on the left side of the engine. It should have 4 allen head bolts holding it in place. Under that cover is your timing setup, which of course has the timing plate. On that plate you will see a few marks, one line has a T under it, and another has a C under it. That is the C mark being discussed.
                            HTH
                              • 1992
                              Okay it has been a while since this was first posted
                              Just wanting feedback from those of you that applied this mod. Problems? Working? Just need some positive feedback before doing this mod.
                                #90
                                I have upgraded every bike I have worked on (I think all) and certainly every bike I have owned with this mod. Never any problems out of any of them.
