Set and forget tensioner (For XJs too)
  • Ivan
    • Jul 2008
    • 2524
    • Hutchinson KS
    nope didn't file the bolt holes at all.
    Also, if you have the valve cover off and for some reason have the cam sprockets loosened up,make sure you tighten those bolts back down. The sprockets make a hell of a noise when they are loose
    Ich habe dich nicht gefragt.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      all i can say is wow
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • 79XS11F
        • Jul 2006
        • 3563
        • Ottawa, Ont. Canada
        Well this is a great discovery isn't it!!! WOW, why the heck would Yamaha not have updated their parts lists to do this by default on the xs11 engine. This change was likely made as a result of the problems owners were having with the tensioner on the 11s. Anyway there's no shortage of them on e-bay at various prices. I just picked up 2 at 10 a piece but shipping to good old Canada will drive the price for the pair to close to 40 bucks. I checked the part price at bike bandit and they are over 100 each new!!!
        Rob
        KEEP THE RUBBER SIDE DOWN
        1978 XS1100E Modified
        1978 XS500E
        1979 XS1100F Restored
        1981 Suzuki GS1100
        1983 Suzuki GS750S Katana
        1983 Honda CB900 Custom
        • petejw
          • 2269
          • sydney australia
          What a great little mod, cheap to.
          Thanx for sharing Ivan.
          pete
          new owner of
          08 gen2 hayabusa
          former owner
          1981 xs1100 RH (aus) (5N5)
          zrx carbs
          18mm float height
          145 main jets
          38 pilots
          • randy
            • Dec 2003
            • 4521
            Rob, good point. In fact, my 80 xs400 had a ratcheting tensioner. It was located under the valve cover! Don't know about the other years' of 400 engines, but the idea was there at least as early as 80.
            • acof911
              • Jun 2005
              • 244
              • S.E PA
              Discoveries like these are why I check this site every day.
              Good tip.
              Thanks Ivan
              • 81xsproject
                • 3185
                • Fortuna, CA
                Does anyone that ended up with more than one want to get ride of one? The eBay selection doesn't look so hot at the moment (new demand). If not I will keep waiting and watching for one to go under 20.
                '81 XS1100 SH
                Sep. 12th 2015
                RIP
                • Bigfoot
                  XS-XJ GURU
                  • Sep 2005
                  • 1422
                  • Kansas City, Missouri
                  Have one of these on my list but might have to wait until the new demand dies down.
                  Harry
                  '79 Standard
                  '82 XJ1100
                  '84 FJ1100
                  Acta Non Verba
                  • Flatlander
                    • 288
                    • Michigan, Thumb
                    X2 for me too. My tensioners plug left me this year. Would like to just replace the whole thing with one of these.
                    Flatlander
                    '81 XS11H
                    • jrplumber1
                      • Sep 2008
                      • 60
                      • North Dakota
                      This is great
                      Just did this to mine today. WOW , it is way nicer looking and auto adjust. You cant go wrong. I love it!!
                      • tarzan
                        • 1700
                        • Chandler,Az.
                        I just won one of these on ebay.$8.95 plus $4.95 shipping.Nobody else bid on it.That is the last part I need to put the 78E back together.WOOHOOO
                        80 SG XS1100
                        14 Victory Cross Country
                        • XSokieSPECIAL
                          • Jun 2009
                          • 1631
                          • Tulsa, OK
                          Check XS XJ parts for sale
                          • XSokieSPECIAL
                            • Jun 2009
                            • 1631
                            • Tulsa, OK
                            I got an extra one Bigfoot but mine wasn't as cheap as tarzan's
                            Listed in parts for sale.
                            • GARTHXS
                              • Nov 2007
                              • 1631
                              • Seattle
                              so how does it work?
                              I should be getting one this week and I am wondering how it works , correct me if I am wrong . so unscrew the big nut on the tensioner push the ratcheting shaft back in and tighten the nut , install then loosen said nut and then tighten again? please help me out here Ivan
                              91 kwaka kz1000p
                              Stock
                              ( Insert clever quote here )
                              • Ivan
                                • Jul 2008
                                • 2524
                                • Hutchinson KS
                                Its not a nut, its a plug, which retains the tensioning spring. With the spring out, the shaft can be retracted. the tensioner is installed just as if you had the original. Instead of loosening the setscrew and re torquing it, you just put the spring and plug back in the tensioner and it will take up the slack. The ratchet will keep the adjustment.
