anything that comes off a space shuttle must be SPENSIVE!
Oh I don't know.. you could walk around Texas a couple years ago and just pick the stuff up. (Has it been long enough to joke about it yet??)
We watched it fly over the house... couple minutes later my Mom called and told me it had vanished... apparently the pretty crystals we saw were pieces of it breaking away...
81 SH SomethingSpecial 81 frame, 80 tank and side covers, 79 tail light and carbs, 78 engine, 750 final drive mod, Geezer rec/reg, 140 mains, LH wheels
79 SF MEAUQABEAUXS 81SHNor'eastah (Old Red) 80 LGBlack Magic 78 EStandard Practice
James 3:17
MoM is Meeting of the Minds. An annual event held at John and Kat's where work is done on bikes for the sake of helping others fix problems and teaching others how these fixes are done. Beer, BBQ, and Riding are also on the agenda (not necessarily in that order).
A colortune is a device that lets you see the color of the fire being produced inside of the combustion chamber. You can then tune the carb to produce the desired result. One way to get the idle mixture screw set correctly after cleaning the carbs. (someone please correct me if I am wrong here.)
So the real question is, Are you coming?
Harry
MoM (Meeting of the Minds) is an excuse to get together and work on bikes... BBQ... ride... and sometimes drink beer...
Ahem
A colortune is a tuning device that allows you to see the spark... Doesn't work so well with the stock coils... but seems to work well with the performance coils... the Carbtune on the other hand... kicks butt... and we have one of those too...
Always a good time though... come on down!
oops... sorry Harry... didn't mean to step on you...
Oh yes... the list... before it gets too lost...
John - steering head bearings on the bagger 80SG
Jeremy - valves
Austin- Complete my bike.... im tired of it
Tod- Drink beer and point... and leave mine the hell alone for once!
Scott - Valve Shims, Tensioner leak, Clutch plates/springs, Sync
Ivan - drink with Tod, install turbo and nitrous with high compression pistons and SRBs off the space shuttle. After drinking, test ride. Or I could just mess with the colortune, since I have never seen one in action before.
Harry - Valve shims if needed. Colortune definitely. Help drink the beer.
James 3:17
Wow sounds cool. I don't know where it is, but most likely can't make it. I got a ton of other things going on. I wouldn't mind bringing the bike up and having some of you guys look at it. Seems to run well but rather have an "expert" check it out.
the list:
Jeremy - valves
I have ordered a new valve cover gasket, is there anything else that I will need to bring if we do the valves on the midnight special?
I don't think so, Harry...
I'm going to check with another member and see if I can get him to send me his shim library so we have a better selection...
Other than that... just a smile and a change of clothes.... maybe some ear plugs...
Hurst, Texas about halfway between Dallas and Ft Worth... so a good ride for you... but doable in a day... easy...
and definitely worth taking the time to come and check out... even with a busy schedule...
the list:
Jeremy - valves
Harry - Valve shims if needed. Colortune definitely. Help drink the beer.[/QUOTE]
James 3:17
Not to far... I was going to do a run this coming weekend that involved TX but things have come up. It was a 1500 mile Saddle Sore run, so coming down there wouldn't be so bad. I do own a trailer also.
The list:
Jeremy - valves
3rd weekend in June 19 - 21? I believe are the dates...
There are a couple of posts with more information...
The list:
Jeremy - valves
Harry - Valve shims if needed. Colortune definitely. Help drink the beer.[/[/QUOTE]
James 3:17
Figures.... I'll be camping that weekend with the family. lol
Jeremy - valves
We DO have a backyard that y'all can camp in... might be tough to get everyone on the bike though...
Originally posted by Trainzz
If there is time , we could insert topcat's fuse block on Thunderpig.
Does TC know you plan on taking his fuse block to put on your bike?
John - steering head bearings on the bagger 80SG Jeremy - valves Austin- Complete my bike.... im tired of it Tod- Drink beer and point... and leave mine the hell alone for once! Scott - Valve Shims, Tensioner leak, Clutch plates/springs, Sync Ivan - drink with Tod, install turbo and nitrous with high compression pistons and SRBs off the space shuttle. After drinking, test ride. Or I could just mess with the colortune, since I have never seen one in action before. Harry - Valve shims if needed. Colortune definitely. Help drink the beer. Lee - Fuse block transplant
James 3:17
