stuck float pin/ Float pin tool
  • Ken Talbot
    • 4251
    • Revelstoke, BC
    #61
    Well done, mro! Simpler to build, less material to waste. Gotta love the way this on-line collaboration works. Did you find you needed to put a wrench on the head of the bolt/screw to get the pin to move, or were you able to work it with finger pressure? No sense pursuing a round, knurled head if it's going to need a wrench to get enough driving force.
    Ken Talbot
    • Wet Rock
      • Dec 2005
      • 51
      #62
      How's This?
      The......."ProMoWetSkidGnepig"
      Pro model....made of metal.......$39.99
      each made to carb specifications of different bikes
      Amature model...$19.99 ....made of stronger type plastic....planned obsolescence (gotta have repeat bussiness)
      Was alot of good thinking going on here.
      I'd settle for all of us to be muti-thousandaires.
      • mro
        • Oct 2005
        • 4276
        • Hayward, California
        #63
        Ken
        Used 10/32 screw. didn't have one w/hex head so just cut off round head and welded nut there. Stuck it in drill press and turned it on. Used a file to cut down end of screw to fit pin hole. Then heated with torch and stuck it into some motor oil.
        Was kind scary how much pressure needed to apply w/wrench, then a little pop and pins came loose.
        sprayed all w/WD40 first too.
        ___________________________________
        ProMoWetSkidGnepig
        You sell em and well make em
        mro
        • Wet Rock
          • Dec 2005
          • 51
          #64
          whooops sorry Ken.
          The..... KenProMro WetSkidGnepig
          • prometheus578
            XS-XJ Super Guru (RESIGNED)
            • Aug 2004
            • 4012
            • Olympia , Wa.
            #65
            "Why my wife stopped washing my boxers..."
            "I'd rearrange the name a little. From a marketting perspective, the "Wet Skid" part sounds like a laundry problem.
            Excellent work, MRO! Brilliant concept, Ken!
            My pivotal contribution was only in stating that it wouldn't work!
            How many carbs did you do, MRO? I'm glad to hear that it took a lot of force...that says that the pins were really in there and that the design concept is solid.
            Another problem worked to completion.
            • mro
              • Oct 2005
              • 4276
              #66
              prometheus578
              Just the 4 on the LG
              Screw needs to be tool steel, although current one seems to be OK. Don't think it would last to long.
              mro
              • CUBuffs
                • 252
                • Castle Rock, Co
                #67
                Hey Gents,
                Been watching your progress on this new tool. I would like to get on the list to buy one. I'm looking forward to trying it out.
                80 XS11 SG
                79 XS750 SF
                74 KZ400
                78 KZ650
                78 KZ750
                • GNEPIG
                  • Apr 2005
                  • 1657
                  • fl
                  #68
                  .. you-da-man mro, good job!
                  • mro
                    • Oct 2005
                    • 4276
                    #69
                    NO PROMISE
                    If your not in a hurry or don't want to make yourself
                    I might have time next weekend and see if I can make 1/2 dozen for you guys to check out.
                    mro
                    • CUBuffs
                      • 252
                      • Castle Rock, Co
                      #70
                      MRO,
                      I can't make one myself and I don't mind waiting. It's pretty chilly in my garage anyhow.
                      80 XS11 SG
                      79 XS750 SF
                      74 KZ400
                      78 KZ650
                      78 KZ750
                        • 5062
                        #71
                        Re: NO PROMISE
                        Oh, I gotta have one of those things! (please)
                        mro
                        • DeanR
                          • Jan 2005
                          • 1493
                          • Finger Lakes NY
                          #72
                          Sounds good to me too!
                          80 SG
                          81 SH in parts
                          99 ST1100
                          91 ST1100
                          • JWSanders
                            • 879
                            • White House, TN
                            #73
                            My ham-handedness has broken far more float posts than I'd care to admit. One of those might keep me from destroying the set of carbs on my spare bike that I will be taking apart soon.
                            If you end up with an extra, I'll be more than happy to test it out.
                            80 XS1100SG
                            81 XS400SH
                            Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
                            A Few Animations I've Made
                            • Ken Talbot
                              • 4251
                              • Revelstoke, BC
                              #74
                              Prototype #kt01
                              Yet another variation on the theme - this one is made from a 1/2" slice off a piece of 2x2 angle iron. Two 3/16" holes elongated to fit over the float posts, one 5/32" hole tapped to M5x0.8mm to fit a M5x16 socket head cap screw. End of screw filed down to just a hair under 2mm diameter.
                              Ken Talbot
                              • mro
                                • Oct 2005
                                • 4276
                                #75
                                Prototype #kt01
                                Hi Ken
                                Have you tried it out?
                                Will allen wrench fit when used on middle carbs?
                                Good idea using angle iron, could file inner curve of angle iron flat so it would fit snug up to post?
                                mro
