Well done, mro! Simpler to build, less material to waste. Gotta love the way this on-line collaboration works. Did you find you needed to put a wrench on the head of the bolt/screw to get the pin to move, or were you able to work it with finger pressure? No sense pursuing a round, knurled head if it's going to need a wrench to get enough driving force.
stuck float pin/ Float pin tool
How's This?
The......."ProMoWetSkidGnepig"
Pro model....made of metal.......$39.99
each made to carb specifications of different bikes
Amature model...$19.99 ....made of stronger type plastic....planned obsolescence (gotta have repeat bussiness)
Was alot of good thinking going on here.
I'd settle for all of us to be muti-thousandaires.
Ken
Used 10/32 screw. didn't have one w/hex head so just cut off round head and welded nut there. Stuck it in drill press and turned it on. Used a file to cut down end of screw to fit pin hole. Then heated with torch and stuck it into some motor oil.Did you find you needed to put a wrench on the head of the bolt/screw
Was kind scary how much pressure needed to apply w/wrench, then a little pop and pins came loose.
sprayed all w/WD40 first too.
___________________________________
ProMoWetSkidGnepig
You sell em and well make em
mroComment
"Why my wife stopped washing my boxers..."
"I'd rearrange the name a little. From a marketting perspective, the "Wet Skid" part sounds like a laundry problem.
Excellent work, MRO! Brilliant concept, Ken!
My pivotal contribution was only in stating that it wouldn't work!
How many carbs did you do, MRO? I'm glad to hear that it took a lot of force...that says that the pins were really in there and that the design concept is solid.
Another problem worked to completion."Damn it Jim, I'm a doctor, not a mechanic!' ('Bones' McCoy)Comment
prometheus578
Just the 4 on the LGHow many carbs did you do, MRO? I'm glad to hear that it took a lot of force...that says that the pins were really in there and that the design concept is solid.
Screw needs to be tool steel, although current one seems to be OK. Don't think it would last to long.
mroComment
Re: NO PROMISE
Oh, I gotta have one of those things! (please)
Originally posted by mro
If your not in a hurry or don't want to make yourself
I might have time next weekend and see if I can make 1/2 dozen for you guys to check out.
mroSkids (Sid Hansen)
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation.Comment
My ham-handedness has broken far more float posts than I'd care to admit. One of those might keep me from destroying the set of carbs on my spare bike that I will be taking apart soon.
If you end up with an extra, I'll be more than happy to test it out.
80 XS1100SG
81 XS400SH
Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
A Few Animations I've MadeComment
Prototype #kt01
Yet another variation on the theme - this one is made from a 1/2" slice off a piece of 2x2 angle iron. Two 3/16" holes elongated to fit over the float posts, one 5/32" hole tapped to M5x0.8mm to fit a M5x16 socket head cap screw. End of screw filed down to just a hair under 2mm diameter.
Ken TalbotComment
