XS11 Off Idle Stumble
    • 2049
    How easily does it start when warm? If it struggles, I would add float valve o’ring leak to your list.
    Marty, it actually starts very easily at any temperature. Mind boggling.
      • 2049
      Here is an update: Wrenched on it all day. Here is what I tried/found:
      Checked all voltages including every pin on the TCI and coils. All normal 12V. 13V-14V while running.
      Compression check - All 4 cylinders within 5 PSI.
      Tried a set of known good used plugs. No change.
      Removed and serviced carb floats. Cleaned seats with polish. Checked fuel level in all 4 carb bowls. No change.
      Installed a mint 1980 advance unit with only 18K original miles. No change.
      I can only draw two last conclusions. A weak coil or the cam jumped time. However, the engine runs smooth (internally) no weird metallic noises.
ID:	891465 Click image for larger version
ID:	891466 Click image for larger version
ID:	891467 Click image for larger version
ID:	891468 Click image for larger version
        • 2049
        Spare Advance unit. No change.
ID:	891471 Click image for larger version
ID:	891472 Click image for larger version
          • 7827
          That is just the vacuum advance unit. Did you service the mechanical advance that lives behind that? If you have a little rust on the weight fulcrum points, it may cause a lag.
            • 2049
            Good point Ray, It is clean, well lubricated, and works perfectly.
              • 8915
              Sometimes those brass vacuum ports on the intake manifold boots can work themselves loose and leak. Don't know if you checked those.
                • 2049
                Success!! Bad #1+4 coil. Runs great!
                  • 8915
                  Awesome. This is the first time I've ever heard of a Dynatek coil failing.
                    • 2049
                    I know. I only had one Dyna coil failure years ago when a crack developed after 25 years of use. And even then, the coils worked but backfired when I rode in the rain or snow. Electronically, I always thought a "bad coil" just opened internally and completely shut off (which happens a lot with power equipment magneto coils like lawn mowers and tractors).
                    BTW, one of the cracked coils (yes, of course I saved them 😀) is running in the XS11 wrapped in electrical tape until the new units arrive.
Name:	New Dyna Coils.jpg
                      • 8915
                      Yep, and now you've gone through the whole bike so you should be good to go for a while. How old was the bad coil?
