Petcock Rebuild
  • Supersport396
    • Nov 2024
    • 66
    • NJ
    #76
    (1) I think you understand the finicky float problem in #1 carb. I don't think you can inspect it without removing the carbs.
    (2) Maybe most of the fork oil had leaked out before you owned the bike. Then maybe you refilled it and now it leaks out? Regarding overfill, I see you measured how much oil to put back in. When you drained it, did you cycle the forks a few times to get our the trapped oil?
    Yes I cycled them after draining.
    Yes I followed that exact thread and stretched the diaphragm.....verified it worked with vacuum pump.
    It was the outboard left carb causing the flooding. not looking forward to carb removal.
      Did you check the float bowl gasket? If it's sticking into the bowl one mm, and the one side of the float is bent by one mm, it may be hanging up. You could try to remove the bowl and trim the gasket with a sharp knife before removing the carbs.
      • Supersport396
        • Nov 2024
        • 66
        • NJ
        #78
        Yes thank you i will give that a try!
        • Supersport396
          • Nov 2024
          • 66
          • NJ
          #79
          Going to try to find some time to pull the carbs and clean/inspect/rebuild. Where is the best source for oem Mikuni parts/kits? I want to avoid poor repop parts.
          Thanks
            I usually buy the jets from Jets-R-Us, and K&L rebuild kits from GeorgeFix.
              Shop for Jetting & Tuning here. Niche Cycle Supply offers great prices on motorcycle parts. Most orders ship the same day | Call us 727-342-5601
              Niche Cycle Supply also sells genuine Mikuni brass.
