Another Charging problem
    • Steverk
      • Oct 2020
      • 35
      • Holland, Michigan
      #47
      When I get home today i'll put a jumper from 12v switched to the black on the field coil and report back on what I find. Appreciate ya'll hangin" in with me through this-- so frustrating.
      Steve K
      1980 xs11 special
      1979 xs400
      1989 Sportster
      2016 KLR
      2016 Africa Twin
      1965 Chevelle
      1970 Wife
        • 735
        Steve, in post #42 you said that the field coil was plugged directly into the Reg. I went out to the shed and looked at the plug on the field coil that I have here and it is a different size than the one on the reg. The field coil has a 2 prong connector, the reg has a 3 prong connector. They can’t connect together. The only thing I am not sure of is what year my field coil is off of. But if all the years used the same one, then the field coil can’t plug into the OEM reg. Could you have a connector plug in the wrong place? Maybe mixed up with a different connector?
        • Steverk
          • Oct 2020
          • 35
          • Holland, Michigan
          #49
          Success!!!
          it only took Deebs11 posting the schematic 6 times for it to sink through my thick skull! Jumped 12V switched to brown wire to the field coil a viola! Tach, gauge lights and a great charge to the battery.
          seems like in my careful rebuild I missed a wire connection. Still not sure where, so if someone can tell me where the switched power connects into the field coil harness I would be great full.
          seriously, thanks to everyone for their patience and advice..
          lesson: things as they are are not always as they were.
          Steve K
          1980 xs11 special
          1979 xs400
          1989 Sportster
          2016 KLR
          2016 Africa Twin
          1965 Chevelle
          1970 Wife
            #50
            Told ya! Glad it worked out
              Here is the wire diagram with the wires outlined in color.
